unable to load my catalog
gouzi
Post by gouzi »
unable to load file " " stream read error
Is there a possibility to repair this please ?
What size is the file? What happened before you got this error? You can try to rename the .bak file to be able to open it.
gouzi
Post by gouzi »
i've not seen the *.bak file i have rename this file and it works thx for your reply ANTP :-)
The size file was 63.5 ko and the good file is 3.25 mo .
