Another bug - movie cover display
Bastardo
Post by Bastardo »
Hello, I think I found another bug, or, rather, a limitation in the program. Suppose, you manually add a picture for a movie. If you download the pic from cdcovers.cc, you get quite a big file with nice resolution. When you add it to Movie Catalog (I use Import function, not link), and have shrinking option enabled, pic dislays well. But if you doubleclick picture to see it in full size, it doesn't display fully, the pic is cut on the right side. This doesn't happen with smaller pictures. Thus I suppose the problem is due to some limitation of max display window size in the program.
That's probably a bug, except if the picture is larger than the screen...
which size is the picture ?
Bastardo
Cover display bug
Post by Bastardo »
Yes, you are right, big cover display only cuts the cover when it is larger than the screen. May I suggest you change the program so that if cover is larger than the screen, it is displayed either in the size reduced to current secreen size, or, better yet, displayed in full size so that one can scroll the picture to see if fully?
Respect,
Bastardo
Yes, I planned to add one of the two possibilities
