Movie list in text
Burroughs
Movie list in text
Post by Burroughs »
How can I get this program (wich by the way is awesome) to show a list of all my movies so that I can right click and copy them to send in an email or use in another text type file.
And is there a way to fix the numbering, cause I have about 1300 DVDs and the list shows all of them but when I goto print them it starts over to zero after 1000.
;) Thanx for any help
You can export to CSV and then open the file in Excel.
What's exactly the problem with numbering? Did you try another template to see if them problem comes from the template?
Burroughs
Movie list in text
Post by Burroughs »
thanx, that worked.
The numbers are fine while i'm adding them, just when i print then out in the three column style it starts back at 0 after it gets to 1000.
Maybe it's simply that the column is too small to contain more than 3 digits? You can try to modify it using the Report Designer.
