Doesn't read some filenames ...
anton
Post by anton »
I noticed that it doesn't read files in some cases , like:
when I don't have avi extension (but it is an avi file) I put * in open dialog, so I can see the file, open it ... and it doesn't read anything :(
also, it doesn't seem to read files with names in unicode (cyrillic) ...
It only import information from .avi and .divx
I should make something to recognize the file by its header and not its extension.
For the unicode, that's strange, but I do not really know how to test that... Anyway this problem will be solved if I change the recognition method (i.e. not using extension anymore)
