Help for scripts
skate
Help for scripts
Post by skate »
Is there the possibility' to adjourn through script a series of film without having to make one film at a time?
You can select multiple movies before calling the script window, then specify that you want to apply the script to selected movies.
skate
Post by skate »
Ok, but when I select the films that want to adjourn, confirmation asks me to save every film and if it doesn't find anything he/she asks me to jump that films.
As I would have to adjourn around 800 films of it I would not like every time to make click with the mouse Ok, Ok... or "it jumps film".
Tks
You can click "Save all" or uncheck the "show results" option.
For other confirmations windows, it depends of the scripts: some have a "batch" option that can be enabled, or a "silent" mode that does not display windows.
skate
Post by skate »
I make sense of better me. I select all the films that I want to adjourn, then F6, therefore I choose the script that I want to use (in my case film.tv.it or filmup.it). When start the search the database introduces me some possible titles of the films, therefore I have to act with the mouse to be able to choose what the film that I look for is and therefore it goes on.
Then when the film finds me with all the characteristics he/she asks me confirmation if I want or less to save the various characteristics (actors, regal, year, etc etc), therefore it saves the same and it goes on with the second film. Then I don't understand whether to select "Salute all."
He anchors thanks.
In the window that shows results you can click "Save all" instead of "Save" so it does not prompts you for each movie.
As I said, for title selection it depends of the scripts: some have an option to prevent this list from appearing.
skate
Post by skate »
Ok, has understood.
But do you know script in Italian that gives me this possibility?'
I don't know, if provided italian scripts do not have this option then it means that there aren't such script.
