Can't input Japanese/Chinese/Korean titles
bluefiberoptics
Post by bluefiberoptics »
When I try to type the Japanese or Korean titles, they just turn into ?????
Does this program support unicode? This program is so perfect!! I just want to be able to type in Japanese and Korean! Thanks!
The program does not support unicode.
It is only able to display characters of your current system codepage.
>_< Ok, I see..
