what a great soft
julien_tahiti
what a great soft
Post by julien_tahiti »
I'm french (like the author I think ? bravo Antoine !!! :grinking:) but I will write in english. So, sorry for my writing.
First, big bravo to Antoine and his team for that great soft !
I'm using it to get info from web and I will make few suggestions :
- auto script : In the newest versions, we can, for certain sites only (Allociné but not DVDFR ! :cry: ), choose to not confirm the title and to automatically choose from the results. This is great cause you can start the script on all your movies and go away. But it would be better if when there are errors (404, 403, socket error and others), it would pass it and continue with the next movie. By now, the script stop until you press the OK button on the error window. Why don't you just make a log file with which errors on which movies and let the script continue.
- When you want to cancel (cancel button), it seems that it don't stop the scripting but just the current task (getting info by POST for example) and jump to the next so you cannot stop the scripting action. The only way I found is to press cancel on the search result window (then it asks if you want to stop the script).
- Sometimes, when scripting, there is a bug : the actual movie is copying on all the following movies (erasing them).
That's all the small problems I found in front of all those great stuff !!!
Once again, bravo !!!
- for the moment the errors cannot be handled by the script. It is one of the planned features for the future.
- I should add the same confirmation window for the cancel button of the progress window.
- Does it happen with only one script or with several of them? Could you indicate how to reproduce the problem?
julien_tahiti
what a great soft
Salut,
Bon, j'ai pas le temps et l'esprit à réfléchir alors je fais ma réponse en français... ;)
Merci pour ta réponse rapide et désolé pour la mienne...tardive.
Complètement satisfait par tes deux premières réponses. Vivement la nouvelle mouture alors !!!
Pour le troisième problème, je n'ai pas été assez attentif lorsque cela s'est passé pour pouvoir te donner le scénario complet mais j'utilisais le script Allociné en mode batch sur une sélection de plusieurs films (avec l'option sans saisie du nom). Je pense que l'erreur a du se passer à la suite d'une erreur "socket error" et j'ai du appuyer sur "ok" et le script a continué. A la fin du traitement, les infos du film s'étaient répercutées sur l'ensemble de la sélection. C'est le genre de truc difficile à reproduire mais j'essaierai d'être plus vigilant la prochaine fois pour te remonter qqch de plus consistant :)
En tout cas, encore bravo à toi car ton logiciel est ultime.
Merci. A+
