A BIG THANKS
Roger
A BIG THANKS
Post by Roger »
Dear Antoine,
Thank you very much for all your work on the movie catalog.
Good to see that a new release (3.5.0.0) has been released.
I'll try to make a decent Dutch translation if I find the time...
Best regards,
Roger Rietdijk
miba_oc
Post by miba_oc »
Hi antp,
just want to thank you for doing a really great job !!!
I searched a prog like this for a long time and now i found it :grinking:
When we will solve the problem with the ofdb+imdb-script (see other thread) i´ll be very contently and happy :D
Thanks and keep up the good work !!!
Greetz from Germany,
miba_oc
ltworf
Post by ltworf »
:grinking: You ROCK! bro this appz is the shits I love it. I especially love the grouping and the export files times and printing. Keep up the good work.
zilog
Post by zilog »
:grinking: :grinking:
Discovered that tool yesterday, and believe it or not, I was using a TXT file for my movies-list (began years ago, was too lazy to convert it :ha: )
more than 1000 movies to enter, but this painstaking process is well worth it when I see the result ;)
Your tool is almost perfect "from the start "(of course, I discover directly a mature version - 3.5.0) :cool:
Some LITTLE things could be better, such as adding some "personal" fields, or direct support for "multi-tagging" without using a script.
Bref, au total, un excellent programme, et çà fait longtemps que je n'ai pas été enthousiasmé par un soft :grinking:
MERCIIIIIIIIIIIIII :)
deathbyaclown
Post by deathbyaclown »
no more things to say...
you are awesome :) wanna have kids with you :hihi:
