Jump From Text To Text?
WizzleWaxX
Post by WizzleWaxX »
Hello,
My dvd list i've exported with Ant Movie Catalog in a html page is quit long. so no i want to know, if there is an script or something else you can put into the html code that you can jump from one to another place.
example
On the begin of my page i wrote what my new movies on the page are. That is only text without any explaination about actors,description or anything else. Then after i told what my new movies are begin's my list with pictures,actors etc etc. Now i want that the text on the top of the page, that that is an link and when you click on it he jump's to the movie that is on my list ( in the html )
Hope you understand my problem?
Sorry for my bad english but hope that you guys understood it and have an solution of it.
Greetz WizzleWaxX
You can add
id="movie$$ITEM_NUMBER"
in attributes one of the tags of the movie block (a <td> or a <p> or any other) then simply do a link to "#movieNNN" where NNN is the number of the movie
WizzleWaxX
Ahh Much Thx!
I've got to try it tonight.
Grtz WizzleWaxX
