Shared variables with Inner Fuse Pascal 2.8
P2
Post by P2 »
With Inner Fuse Pascal 2.8 (used by AMC for scripting) is possible to use shared variables as functions parameter like Delphi? :??:
Example:
procedure MyProcedure(var MyString: string);
  MyString := MyString + 'add this';
where "var MyString" is variable shared from main script to procedure (i.e. external library).
Thanks for aid.
Pivello
No, "var" strings do not work with functions that are not in the same unit :(
that's why I've put a global "RemainingText" variable in StringUtils1
Another solution is to define a new type in the shared unit :
type MyStr = string;
then use only this kind of variable instead of string.
But when you have to pass a string to a predefined function (GetPage, etc.) you will have to copy the MyStr-typed variable to a string-typed variable.
P2
Post by P2 »
Thanks for answer, Antoine.
Btw, do you have estimated the possibility to use the new Inner Fuse Pascal Script 3.0? http://www.remobjects.com/?ps
Regards
Pivello
Some time ago I wanted to update to v3 but there were lots of changes to do.
Now that I made the script part of AMC more complex, the update would require even more work.
It is not a high priority for me, since the script system works quite well as it is.
P2
Post by P2 »
Ok. I understand.
Thanks.
Pivello
