[ES] Sugerencias
Corsario
[ES] Sugerencias
Post by Corsario »
  • Añadir soporte para importar/exportar a formato de Microsoft Access (*.mdb), aunque tenga que ser sin imágenes...
  • Acerca del script para obtener los datos de los codecs, el bitrate, etc... también añadir la obtención de esos datos en el caso de VCDs y xVCDs (Como CVCD, KVCD, SVCD...).
  • La posibilidad de añadir y eliminar campos a rellenar. Ya que por ejemplo, yo no uso el campo de "Valoración" y así, poder eliminarlo. Pero teniendo también la posibilidad de añadir un campo propio. Me interesa principalmente la posibilidad de eliminar campos a rellenar.
Gracias, y espero ayudar un poco en la mejora de este fantástico programa.
¡Saludos!
I plan to add a customizable import from Access in a future version. Actually the "DivxManager" importation loads an Access DB that has specific columns. So I would just have to let the user assign columns like he can do for CSV (by the way, you can save your Access table to CSV and then import the CSV)
VCD and SVCD info can be imported (or should be) with AMC 3.5, like the info from .AVI files were imported in previous versions.
About your last question, I do not understand it, sorry (I do not understand spanish actually :D)
serguiri
Post by serguiri »
He's asking for custom fields. And the option to turn them on or off because he doesn't use them. I think! Because he's talking about the "valoración" field... there is no such field (maybe he means 'rating'). Well who cares.
Antoine. If someone asks you something in Spanish don't hesitate to send them to me (I'm already used to it :p)
Well, about new fields it will be for version 4, but I do not know if I'll make that customizable or not ;)
