how to get my picture information?
icecubix
Post by icecubix »
I have some films with picture and some films without. I want modify one script to get the picture only if I don't have it.
Do you know how can I see if I have the picture or not? (and it's size?).
I had seen the getField(fieldxxxxx) function, but don't exist the "fieldPicture".
Thanks in advance
Icecubix
It is not possible currently.
I plan to add that in a future version.
icecubix
Post by icecubix »
Ok, thanks, antp.
Maybe also you can do a static variable that maintains its value only between batch jobs, instead of doing it during all the execution of the program.
Congratulations by a brilliant program :grinking:. I'm a programmer and shortly I will make my own little contributions to the forum.
[/b]
There is already possible to set "static" variables, but I do not really understand what you want to do with them :??:
icecubix
is not important
Post by icecubix »
Well, don't worry :p . I have lots of films bad cataloged (I didn't have ant movie catalog) and I want to take the maximum advantage of the batch jobs, that act in a different way every time according to my needs, but I can do it touching the script dinamically.
Thanks again ;)
ScorEpioN
Post by ScorEpioN »
This week-end i had the same problem.
i would do a mass update but search fonction couldn't found empty field :(
so i have do an update to my script :
UPDATE FIELDS v22 du 31/03/2005 *EN,FR*
Coche les films si champs vide (Check Empty Field) : Fonction qui coche les films ayant le champs choisi vide (pratique avant de faire des MAJ massives).
Click here to find UPDATE FIELDS last version
For picture i can't :badidea: (fieldPicture exist (number 99) but doesn't work with getfield)
ScorEpioN wrote: i would do a mass update but search fonction couldn't found empty field
Leave the search value field empty and check the "whole field" option ;)
ScorEpioN
Post by ScorEpioN »
oups i have not found this tip... but my script is good if you want to do search with multiple choice :
1°) you use script for all movie (no url for example)
2°) second use only on check movie (no label for example)
3°) ...
Finally you find movie wth no url and no label :D
