[MOD] Bug in Yahoo Cinema (ES).ifs - Solved here
enriquevagu
Post by enriquevagu »
When reading some movies data, the spanish script from Yahoo! page gets "blocked", just try searching for "Los increíbles" (The Incredibles).
The problem is in the "Calificación" field, which is taken from the number of coloured stars (from 0 to 5) in the Yahoo Page. The value for the field is the number of yellow stars*2. The problem is that, if the movie is very good and it has 5 yellow stars at the Yahoo! page, the script will roll forever searching for the first (unexistant) white star, in an infinite loop.
The solution for this problem is to substitute line #186:
 while EndRating = 0 do
with the following one:
while (EndRating = 0) and (irate < 5) do
I hope it will get corrected in the next version of the script.
Very good job!
Enriquevagu
Thanks ;)
folgui
Post by folgui »
Thanks enrique
:grinking:
folgui
Post by folgui »
Hello!
Here's the updated script with changed version and date, so users can easily detect latest version of script.
antp, copy/save it to update latest version of script.
Regards, folgui
Authors=Andrea Cristaudo (achris@tiscalinet.it) & folgui (folgui@bigfoot.com)
Title=Yahoo!Cinema Spain
Description=Movie importation script for Yahoo!Cinema Spain
Site=http://es.movies.yahoo.com
Language=ES
Version=1.2 (30 Mar 2005)
Requires=3.5.0
Comments=Updated by folgui for Spanish Database Support and more info importing. Reported/fixed bug by enriquevagu, thanks!|
LargePic=1|1|0=It imports default (small) pic|1=It imports a larger pic
program YahooCinema;
TheMovieAddress: string;
result := -1;
if StartAt < 0 then
  StartAt := 0;
   result := i;
  InitialPos: Integer;
  InitialPos := Pos(EndTag, S);
  Delete(S, 1, InitialPos + 1);
procedure AnalyseLargePicPage(Address: string);
LineNr: integer;
ImageURL: string;
LineNr := FindLine('<img src="http://eur.news1.yimg.com/eur.yimg.com/', Page, 0);
If LineNr <> -1 then
  ImageURL := TextBetween (Line, '<img src="', '"');
  GetPicture (ImageURL);
LineNr: integer;
BeginPos: integer;
LineNr := FindLine('<font face=arial,helvetica size=+1><b>Resultados de búsqueda</b></font>', Page, 0);
if LineNr = -1 then
  AnalyzeMoviePage(Page);
  AddMoviesTitles(Page);
  if TheMovieAddress='' then
 Fine: Integer;
 EndActors: Integer;
 EndProducers: Integer;
 EndMusics: Integer;
 EndDirectors: Integer;
 EndPhotographers: Integer;
 EndWriters: Integer;
 EndRating: Integer;
 strActors: string;
 strComments: string;
 strProducers: string;
 strMusics: string;
 strDirectors: string;
 strPhotographers: string;
 strWriters: string;
 ImageURL: string;
 strTemp: string;
 BeginPos, EndPos: Integer;
 Field: integer;
 irate: integer;
Page.Text := StringReplace(Page.Text, ' ', '');
Fine := 0;
  LineNr := FindLine('<FONT color=white face="arial, helvetica"><b>', Page, 0);
if LineNr > -1 then
  //Translated Title
  HTMLRemoveTags(Line);
  Line := StringReplace(Line,'"','');
  SetField(fieldTranslatedTitle,Line);
   LineNr := LineNr + 1;
   //GetPicture of Movie
   if GetOption('LargePic') = 0 then
    // Import Small Picture
      if pos('html"><img src="http:', Line) <> 0 then
        Delete(Line, 1, pos('<img ', Line) + 9);
        Delete(Line, pos('" border=', Line), pos('</a>', Line) + 1);
        GetPicture(Line);
   // Import Large Picture
      if pos('Agrandar la imagen</a>', Line) <> 0 then
        ImageURL := TextBetween(Line, '<a href="', '">Agrandar la imagen</a>');
        AnalyseLargePicPage('http://es.movies.yahoo.com' + ImageURL);
   //Original Title
   if pos('<b>Título original:</b>', Line) <> 0 then
     Delete(Line, 1, 16);
     SetField(fieldOriginalTitle, Line);
   //Country and Year
   else if pos('<b>País y año:</b>',Line) <> 0 then
     SetField(fieldCountry, Line);
     SetField(fieldYear, copy(Line, 2, 4));
   //Category and Length
   else if pos('<b>Género:</b>', Line) <> 0 then
     Delete(Line, 1, 7);
     SetField(fieldCategory, Line);
     Delete(Line, 1, 9);
     SetField(fieldLength, copy(Line, 1, 3));
     If GetField(fieldLength) = '' then
      SetField(fieldLength, copy(Line, 1, 2));
   //Rating
   else if pos('<b>Crítica:</b>', Line) <> 0 then
     irate := 0;
     EndRating := pos('<img src="http://eur.i1.yimg.com/eur.yimg.com/i/de/mo/1sg.gif" width=10 height=9>', Line);
       irate := irate + 1;
     SetField(fieldRating, IntToStr(irate*2));
   //Description
   else if pos('<b>Sinopsis:</b>', Line) <> 0 then
     LineNr := LineNr + 2;
     HtmlRemoveTags(Line);
     SetField(fieldDescription, Line);
   //List of Actors
   else if pos('<b>Actor / Actriz:</b>', Line) <> 0 then
     strActors := '';
     EndActors := pos('</font></td></tr>', Line);
     while EndActors = 0 do
       if strActors = '' then
        strActors := Line
        strActors := strActors + ' ' + Line;
     SetField(fieldActors, strActors);
   else if pos('Montador:</b>', Line) <> 0 Then
     strComments := 'Montaje: ' + Line + #13#10;
   // Music for Comments
   else if pos('<b>Musica:</b>', Line) <> 0 then
     strMusics := '';
     EndMusics := pos('</font></td></tr>', Line);
     while EndMusics = 0 do
       if strMusics = '' then
        strMusics := Line
        strMusics := strMusics + ' ' + Line;
     strComments := strComments + 'Música: ' + strMusics + #13#10;
   // Aditional Music Author for Comments
   else if pos('<b>Compositor (música adicional):</b>', Line) <> 0 then
     strComments := strComments + 'Compositor: ' + Line + #13#10;
   //Director
   else if pos('<b>Director:</b>', Line) <> 0 then
     strDirectors := '';
     EndDirectors := pos('</font></td></tr>', Line);
     while EndDirectors = 0 do
       if strDirectors = '' then
        strDirectors := Line
        strDirectors := strDirectors + ' ' + Line;
     SetField(fieldDirector, strDirectors);
   //Photography for Comments
   else if pos('<b>Fotografía:</b>', Line) <> 0 then
     strPhotographers := '';
     EndPhotographers := pos('</font></td></tr>', Line);
     while EndPhotographers = 0 do
       if strPhotographers = '' then
        strPhotographers := Line
        strPhotographers := strPhotographers + ' ' + Line;
     strComments := strComments + 'Fotografía: ' + strPhotographers + #13#10;
   //Screenplay Writer for Comments
   else if (pos('<b>Guionista:</b>', Line) <> 0) Or (pos('<b>Guión', Line) <> 0) then
     strWriters := '';
     EndWriters := pos('</font></td></tr>', Line);
     while EndWriters = 0 do
       if strWriters = '' then
        strWriters := Line
        strWriters := strWriters + ' ' + Line;
     strComments := strComments + 'Guionista: ' + strWriters + #13#10;
   //Producer
   else if (pos('<b>Producción:</b>', Line) <> 0) Or (pos('<b>Productor', Line) <> 0) then
     strProducers := '';
     EndProducers := pos('</font></td></tr>', Line);
     while EndProducers = 0 do
       if strProducers = '' then
        strProducers := Line
        strProducers := strProducers + ' ' + Line;
     SetField(fieldProducer, strProducers);
   // More Comments
   else if pos('<b>Notas de Producción</b>', Line) <> 0 then
     strTemp := TextBetween(Line, '<FONT face=arial size=-1>', '<a href="');
     HtmlDecode(strTemp);
     strComments := strComments + '------------------------------';
     strComments := strComments + #13#10 + strTemp;
   // More Comments
   else if pos('<b>Crítica</b>', Line) <> 0 then
   else if Line = '</html>' then
    Fine := 1;
  until Fine = 1;
  SetField(fieldComments, strComments);
//DisplayResults;
NewLineNr: Integer;
TheMovieAddress := '*';
LineNr := 0;
LineNr := FindLine('<font face=arial,helvetica><b>Resultado de películas</b>',Page,LineNr);
LineNr := LineNr + 3;
PickTreeAdd('Resultados encontrados:','');
while LineNr > 2 do
  BeginPos := pos('<li><a href="',Line)+13;
  EndPos := pos('">',Line);
  MovieAddress := copy(Line,BeginPos,EndPos-BeginPos);
  Delete(Line,1,EndPos + 1);
  BeginPos := 1;
  EndPos := -1;
  MovieTitle := Line;
  HTMLRemoveTags(MovieTitle);
  HTMLDecode(Movietitle);
  NewLineNr := FindLine('<li><a href="',Page,LineNr+1);
  if NewLineNr <> (LineNr + 1) then
   LineNr := 2
   LineNr := NewLineNr;
  if TheMovieAddress='*' then
   TheMovieAddress := MovieAddress
   TheMovieAddress := '';
if CheckVersion(3,5,0) then
  if Input('Yahoo!Cinema España', 'Introduce el título de la película (enter movie title):', MovieName) then
   AnalyzePage('http://es.search.movies.yahoo.com/search/movies_db_es?mt='+UrlEncode(MovieName));
otreux
Post by otreux »
Don't work :(
otreux wrote:Don't work :(
It is 8 years old, the site most likely changed since then...
You're doing forum archaeology there :lol:
