Selection impression of scripts
Edu
Post by Edu »
Seleccion impresion of scripts
Greetings al forum.
In the previous versions, could be elected since the menu to PRINT the movies desired.
In the new one version, this is not possible, or do not I find it.
I find that in the previous versions was a lot but flexible the to generate impressions since itself podia select/deseleccionar of form rapida and simple, without having that to abandon this menu
Thanks.
It translated with aid of GOOGLE
Seleccion impresion de scripts
Saludos al foro.
En las versiones anteriores, se podía elegir desde el menú IMPRIMIR las películas deseadas.
En la nueva version, esto no es posible, o no lo encuentro.
Encuentro que en las versiones anteriores era mucho mas flexible el generar impresiones ya que se podia seleccionar/deseleccionar de forma rapida y sencilla, sin tener que abandonar este menú
Gracias.
Traducido con ayuda de GOOGLE
I hope that I understood your message correctly :D
So you are asking how to select which movies to print ?
In the print window there are radiobutton options to print all movies, selected movies, etc.
If you select the option "selected movies", then only the movies that were selected in main window will be printed.
In previous version by default it was selecting movies that were selected in main window.
