[REL] AllMovie.com
KaraGarga
[REL] AllMovie.com
Post by KaraGarga »
zile asked me to improve and correct the current AMG script for 3.5.0 Final version.
I made some modifications and enchancements, also some bugs were corrected.
I could not test it much but seem to OK. If you find a bug please let me know.
KG
Authors=Hubert Kosior, KaraGarga
Title=All Movie Guide
Description=All Movie Guide detailed info import with small picture
Site=http://allmovie.com
Language=EN
Version=0.3 / 04.2005
Requires=3.5.0
Comments=send bugs and reports to: hubert@tm1.net|a bug corrected by Antoine Potten|to do:| - producer's name instad of producing company| - display movie categories when movie list hit (after searching)
CategoryOptions=3|3|1=Only import firts category|2=Import all categories and divide by "/"|3=Import all categories and divide by ","
ProducerOptions=0|0|0=Import Production Companies into Producer Field|1=Import Theme into Producer Field|2=Import Tones into Producer Field|3=Import Moods into Producer Field|4=Import Releaser Company into Producer Field
SynopsisOptions=2|1|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Synopsis
ReviewOptions=2|2|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Review
AwardsOptions=2|2|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Awards List
CastOptions=3|3|1=Import Cast divided by ";"|2=Import Cast as a list (AMG Default)|3=Import Cast as a list (like IMDB)|4=Import Cast as a list within paranthesis|5=Import Cast within paranthesis
FieldforCredits=2|2|0=DO NOT import Production Credits|1=Import Production Credits into Description Field|2=Import Production Credits into Comments Field
CreditsOptions=2|2|1=Import Credits as a list (like AMG)|2=Import Credits as a list (like IMDB)|3=Import Credits as a list (within paranthesis)
program AllMovie;
  StringUtils1;
// simple string procedures
  while Pos(Old, S) > 0 do
  Result := S;
// Loads and analyses page from internet (list of movies or direct hit)
  // movie list
  Sleep(500);
  if Pos('movie titles like: ', Page.Text) > 0 then
    PickTreeAdd('Search results', '');
    AddMoviesTitles(Page);
      AnalyzePage(Address);
  // refine search
  if Pos('Sorry, there is too many possible matches, please adjust your search.', Page.Text) > 0 then
    ShowMessage('Sorry, there is too many possible matches, please adjust your search.');
    if Input('All Movie Import', 'Enter the title of the movie:', MovieName) then
      AnalyzePage('http://allmovie.com/cg/avg.dll?p=avg&type=2&srch=' + URLEncode(MovieName));
  // direct hit
    if CanSetField(fieldURL) then SetField(FieldURL, Address);
    AnalyzeMoviePage(Page)
// Extracts movie details from page
procedure AnalyzeMoviePage(MoviePage: TStringList);
  Page: string;
  Value: string;
  Page := MoviePage.Text;
// Original title
  Value := TextBetween(Page, '<FONT SIZE="+2"><B>', '</B>');
// Year
  SetField(fieldYear, GetStringFromHTML(Page, '<B>'+GetField(fieldOriginalTitle)+'</B>', '</TR>', '</B>'));
// Country
  SetField(fieldCountry, GetStringFromHTML(Page, '<B>'+GetField(fieldOriginalTitle)+'</B>', '<I>', '</I>'));
// Length
  SetField(fieldLength, GetStringFromHTML(Page, '<B>'+GetField(fieldOriginalTitle)+'</B>', '</I> - ', ' min'));
// AKA -> translated title
  SetField(fieldTranslatedTitle, GetStringFromHTML(Page, '>AKA', '</TD>', '</td>'));
// Rating (multiplied by 2, because 0 <= AMG rating <= 5)
  Value := GetStringFromHTML(Page, '>AMG Rating', 'alt="', ' Stars');
  if Length(Value) > 0 then
   SetField(fieldRating, FloatToStr(StrToFloat(Value)*2));
// Director
  SetField(fieldDirector, GetStringFromHTML(Page, '>Director', '</TD>', '</td>'));
// Genre -> category
  if GetOption('CategoryOptions') = 1 then
  Value := TextBetween(Page, 'Genre/Type </TD>', '</A>');
  if Value <> '' then
    HTMLRemoveTags(Value);
  if GetOption('CategoryOptions') = 2 then
  Value := TextBetween(Page, 'Genre/Type </TD>', '</td>');
    if Value <> '' then
    Value := StringReplace(Value, ',', ' /');
  if GetOption('CategoryOptions') = 3 then
  SetField(fieldCategory, GetStringFromHTML(Page, '>Genre/Type', '</TD>', '</td>'));
// Producing company  -> producer
  if GetOption('ProducerOptions') = 0 then
    //SetField(fieldProducer, GetStringFromHTML(Page, 'Produced by ', '<TD>', '</TD></TR>'));
    Value := TextBetween(Page, 'Produced by ', '</A></TD></TR>');
    if Value <> '' then
  if GetOption('ProducerOptions') = 1 then
  Value := TextBetween(Page, 'Themes ', '</A></td></tr>');
    if Value <> '' then
  if GetOption('ProducerOptions') = 2 then
  Value := TextBetween(Page, 'Tones ', '</A></td></tr>');
    if Value <> '' then
  if GetOption('ProducerOptions') = 3 then
  Value := TextBetween(Page, 'Moods ', '</A></td></tr>');
    if Value <> '' then
  if GetOption('ProducerOptions') = 4 then
  SetField(fieldProducer, GetStringFromHTML(Page, '>Released by', '</TD>', '</TD>'));
// Image
if CanSetPicture then
  Value := GetStringFromHTML(Page, 'http://image.allmusic.com', '', '"');
  if Length(Value) > 0 then GetPicture(Value);
// Cast -> actors
// adjust semicolons
  Value := StringReplaceAll(Page, '</I></TD></TR>', '; ');
  Value := GetStringFromHTML(Value, '<A Name="CAST">', '</td></tr>', '</TABLE>');
    // remove double spaces if only actor name given
    while Pos('  ', Value) > 0 do
    Delete(Value, Pos('  ', Value), 2);
    // remove trailing "; "
    if Copy(Value, Length(Value) - 1, 2) = '; ' then
    Value := Copy(Value, 0, Length(Value) - 2);
    if GetOption('CastOptions') = 1 then
      SetField(fieldActors, Value);
    if GetOption('CastOptions') = 2 then
      Value := StringReplace(Value, '; ', #13#10);
    if GetOption('CastOptions') = 3 then
      Value := StringReplace(Value, '-', '...');
    if GetOption('CastOptions') = 4 then
      Value := StringReplace(Value, '; ', ')'+#13#10);
      Value := StringReplace(Value, '-', '(');
    if GetOption('CastOptions') = 5 then
      Value := StringReplace(Value, '; ', '), ');
// Plot synopsis
if CanSetField(fieldComments) or CanSetField(fieldDescription) then
  Value := GetStringFromHTML(Page, '<A Name="PLOT">', '</table>', '</table>');
  if GetOption('SynopsisOptions') = 0 then
  if GetOption('SynopsisOptions') = 1 then
    SetField(fieldDescription, 'AMG SYNOPSIS: '+Value+#13#10+#13#10);
  if GetOption('SynopsisOptions') = 2 then
    SetField(fieldComments, 'AMG SYNOPSIS: '+Value+#13#10+#13#10);
// Review -> description
  Value := GetStringFromHTML(Page, '<A Name="REVIEW">', '</table>', '</table>');
    if GetOption('ReviewOptions') = 0 then
    if GetOption('ReviewOptions') = 1 then
      SetField(fieldDescription, GetField(fieldDescription)+'AMG REVIEW: '+Value+#13#10+#13#10);
    if GetOption('ReviewOptions') = 2 then
      SetField(fieldComments, GetField(fieldComments)+'AMG REVIEW: '+Value+#13#10+#13#10);
// Awards -> description
// adjust spaces and line feeds
  Value := StringReplaceAll(Page, '> <FONT', ''); // space before title
  Value := StringReplaceAll(Value, '</FONT> </td><td WIDTH=209>', ' - '); // minus before name
  Value := StringReplaceAll(Value, ' </A></FONT></td>', ' - '); // minus after name (1)
  Value := StringReplaceAll(Value, ' </FONT></td>', ' - '); // minus after name (2)
  Value := StringReplaceAll(Value, '</FONT> </td></tr>', + #13#10); // newline after academy name
  Value := GetStringFromHTML(Value, '<A Name="AWRD">', '</td></tr>', '</TABLE>');
  Value := StringReplaceAll(Value, '  ', ' ');
  Value := StringReplaceAll(Value, ' - - ', ' - ');
    if GetOption('AwardsOptions') = 0 then
    if GetOption('AwardsOptions') = 1 then
      SetField(fieldDescription, GetField(fieldDescription)+'AWARDS:'+#13#10+Value+#13#10);
    if GetOption('AwardsOptions') = 2 then
      SetField(fieldComments, GetField(fieldComments)+'AWARDS:'+#13#10+Value+#13#10);
// ProductionCredits
  Value := GetStringFromHTML(Value, '<A Name="CRED">', '</td></tr>', '</TABLE>');
      if GetOption('FieldforCredits') = 1 then
          if GetOption('CreditsOptions') = 1 then
            SetField(fieldDescription, GetField(fieldDescription)+'PRODUCTION CREDITS:'+#13#10+Value);
          if GetOption('CreditsOptions') = 2 then
          if GetOption('CreditsOptions') = 3 then
            SetField(fieldDescription, GetField(fieldDescription)+'PRODUCTION CREDITS:'+#13#10+Value+')');
      if GetOption('FieldforCredits') = 2 then
            SetField(fieldComments, GetField(fieldComments)+'PRODUCTION CREDITS:'+#13#10+Value);
            SetField(fieldComments, GetField(fieldComments)+'PRODUCTION CREDITS:'+#13#10+Value+')');
// remove trailing newline from description or comments
Value := GetField(fieldDescription);
if Copy(Value, Length(Value) - 1, 2) = #13#10 then
Value := GetField(fieldComments);
// Adds movie titles from search results to tree
procedure AddMoviesTitles(ResultsPage: TStringList);
  Page: string;
  Page := ResultsPage.Text;
  // Every movie entry begins with string "<A HREF='/cg/avg.dll?"
  while Pos('<A HREF="/cg/avg.dll?', Page) > 0 do
    CutBefore(Page, '<A HREF="/cg/avg.dll?');
    MovieAddress := 'http://allmovie.com' + GetStringFromHTML(Page, '<A', '"', '">');
    MovieTitle := GetStringFromHTML(Page, '<A', '', '</tr>');
    MovieTitle := StringReplace(MovieTitle, ')', '),  ');
    CutAfter(Page, '</tr>');
    // add movie to list
// Extracts single movie detail (like director, genre) from page
  Result := '';
    CutBefore(Page, StartTag);
    if Length(CutTag) > 0 then
      CutAfter(Page, CutTag);
    // remove html tags and decode html string
    HTMLRemoveTags(Result);
    HTMLDecode(Result);
//  ShowMessage('DEBUG: GetStringFromHTML - StartTag "'+StartTag+'", CutTag "'+CutTag+'", EndTag "'+EndTag+'", Result "'+Result+'" ___ '+Page);
procedure RemovePronoun(var Str: string);
  s: string;
  c: char;
  // remove pronouns
  s := UpperCase(Copy(Str, 0, 4));
  if (s = 'LES ') or (s = 'UNE ') or (s = 'THE ') then
    Str := Copy(Str, 5, Length(Str) - 4)
    s := Copy(s, 0, 3);
    if (s = 'LE ') or (s = 'UN ') then
      Str := Copy(Str, 4, Length(Str) - 3)
      s := Copy(s, 0, 2);
      if (s = 'L''') or (s = 'L ') or (s = 'A ') then
        Str := Copy(Str, 3, Length(Str) - 2)
  // remove non-letters, non-digits and non-spaces
  s := '';
  for i := 1 to Length(Str) do begin
  c := StrGet(Str, i);
    if ((c<'a') or (c>'z')) and
       ((c<'A') or (c>'Z')) and
       ((c<'0') or (c>'9')) and
       (c<>' ') then
      s := s + Copy(Str, i, 1);
  Str := s;
  if CheckVersion(3,5,0) then begin
    if MovieName = '' then MovieName := GetField(fieldTranslatedTitle);
    if Input('All Movie Import', 'Enter title (only letters, digits and spaces):', MovieName) then
      if Pos('allmovie.com', MovieName) > 0 then
        AnalyzePage(MovieName)
        RemovePronoun(MovieName);
        AnalyzePage('http://allmovie.com/cg/avg.dll?p=avg&type=2&srch=' + StringReplace(URLEncode(MovieName), '%20', '+'));
* Updated: 12.04.2005
Thanks ;)
zile
Post by zile »
Thanky you very much, KaraGarga. That was super fast :grinking:
zile
some errors
Post by zile »
Few bugs should be corrected in this script!
1. When using settings "0" in "producer options" the data form
"category options" are imported in producer field.
2. Country, year and lenght are not imported at all.
Thank you!
KaraGarga
Re: some errors
Post by KaraGarga »
zile wrote:1. When using settings "0" in "producer options" the data form "category options" are imported in producer field.
Corrected. Please look at above updated script.
zile wrote:2. Country, year and lenght are not imported at all.
It works for me. Are you sure movie has this info at AMG? If so could you send the link of the movie.
If any problem let me know :)
zile
Post by zile »
Great!
All seems to working now...
Thank you. :)
PS: Probably there was no info about length, etc...
zile wrote:Great!
Thank you. :)
Ok done some further testing and found that the following title is not imported correctly.
ex: Intimate Universe: The Human Body - Lifestory
There is really little info about this doc.
I see missing category, lenght and wrong country importation. (Film Expert Check. )
Thanks.
zile
Post by zile »
KaraGarga
Post by KaraGarga »
It seems AMG give up using http://allmovie address or has some difficulties with this address. If you see "Timeot Error" by using this script please find:
and replace with
AnalyzePage('http://www.allmovie.com/cg/avg.dll?p=avg&type=2&srch='
me
allmovie not working
Post by me »
I have tried all of the above but still get a time out error. I am using v3.5.0.2. Thanks CG
