imdb script, picture problem
Liddan
Post by Liddan »
ANT Movie Cataloge v3.5.0
I use this setting:
"2-> IMDB large image if found easily, else small image"
At times when I use the script to import information it finds no picture, even as there is a picture on the imdb site.
If I change the settings to:
"1-> IMDB small image, from the main movie page"
The script imports a image..
So what is wrong?
Re: imdb script, picture problem
Liddan wrote: So what is wrong?
I don't know :D Can you give me an movie title that has this problem?
Liddan
Post by Liddan »
Sadly I can't remember, but it happens somewhere around 1 out of 25 movies I add. And I have been adding alot the last couple of days, 200 entries in 2 days :)
Anyway, next time I encounter the problem I will post the movie here.
Liddan
Post by Liddan »
I have almost only added series lately, but just now I added the movie Primer.
And guess what? The problem occured.
This is the URL I used to import information:
http://www.imdb.com/title/tt0390384/
Edit:
Will post more movies with the same problem when i encounter them.
Liddan
Post by Liddan »
Will just add new movies with the problem in this post, wont create a new one...
The Merchant of Venice
http://us.imdb.com/title/tt0379889/
Lemony Snicket's A Series of Unfortunate Events
http://us.imdb.com/title/tt0339291/
Edit #1:
The Phantom of the Opera
http://us.imdb.com/title/tt0293508/
I'll check that when I'll merge IMDB script with this modified version:
viewtopic.php?t=1975
(that you could try, maybe it will work better)
