Date Added Bug
Fuzio
Date Added Bug
Post by Fuzio »
I import movie list from csv (exported from excel). Now when i try to set date added something strange happen-i can only set this on one movie, when i set date added on second movie then switch to another movie and goes back - info disapear.to set the info on next movie i have to exit program and start it again,set the info, and close prog,start,set the info on next movie ....
Could u check this? mayby i do sth wrong?
I'm using ant 3.4.0 (07/10/2002) on win xp
I do not know from where this bug comes, but somebody already told me about that (or a similar problem).
You have to check, uncheck, then check again the little checkbox that is in front of the date before setting it.
Fuzio
Post by Fuzio »
thx, it works:)
