Importing multiple files from a DVD
saba
Post by saba »
Hello Antp,
Firstly, I want to say I absolutely love you program! I have gone through testing about 7 different programs and I find your program is the best – in my humble opinion. :lol:
I have been until now using a program called Disclib (http://www.lyrasoftware.com/disclib/) it has one simple feature which I can’t find in ver 3.5.0. I put a DVD full of stuff into the computer, click ‘add volume’. It grabs everything on the dvd and adds it to the db.
Does Ant Movie Catalog have this function? :??: The only way I have been able to do it is by dragging one file at a time, which is taking forever. Can a script be written to do this?
Can you suggest an easier solution?
Again many thanks for this wonderful program. :grinking:
Saba
It is not currently possible to import multiples files as multiple movies at the same time, but it is one of the high priority planned features ;)
Until then you can use this solution :
viewtopic.php?t=1961
but if it is to import movies from a DVD (max 6 movies I guess) it won't be much faster than doing each one manually.
saba
Post by saba »
Thanks mate! :)
