[Cz] CSFD.CZ - Script Not Work - Change structure web
Petr
DanC
Re: [Cz] CSFD.CZ - Script Not Work - Change structure web
Upravil jsem skript na novou strukutru stranek csfd.czPetr wrote:Don´t work import from csfd.cz, the best Movie Catalog in Czech republic. Structure WWW pages was change. Please, could you somebody to change this script ? Thak you very much.
Skript je urcen pro verzi 3.5.0
Snad je vse v poradku, zkousel jsem to asi na 10 filmech.
Dan
Authors=Dmitry501,Inteline
Title=csfd.cz
Description=Imports from csfd.cz
Site=www.csfd.cz
Language=CZ
Version=
Requires=3.5.0
Comments=
License=This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version. |
program Csfd_cz;
BaseAddress = 'http://www.csfd.cz/';
result := -1;
if StartAt < 0 then
StartAt := 0;
result := i;
procedure RozdelStat(Line: string);
var CarkaPos1, CarkaPos2, minPos : Integer;
//rozdeleni statu, roku a delky
CarkaPos1 := Pos(',', Line);
if CarkaPos1 > 0 then
CarkaPos2 := Pos(',', copy(Line, CarkaPos1+1, length(Line)));
if CarkaPos2 > 0 then
minPos := Pos('min', copy(Line, CarkaPos1+CarkaPos2+1, length(Line)));
if minPos > 0 then
SetField(fieldCountry, trim(copy(Line, 0, CarkaPos1-1)));
SetField(fieldYear, trim(copy(Line, CarkaPos1+1, CarkaPos2-1)));
SetField(fieldLength, trim(copy(Line, CarkaPos1+CarkaPos2+1, minPos-1)));
function GetDirector(Line: string): String;
var BeginPos : Integer;
result := '';
BeginPos := Pos('Režie:', Line);
if BeginPos > 0 then
Delete(Line,1,BeginPos+5);
BeginPos := Pos('<br>', Line);
if BeginPos = 0 then BeginPos := Length(Line);
result := copy(Line, 1, BeginPos);
HTMLDecode(result);
HTMLRemoveTags(result);
result := Trim(result);
function GetActor(Line: string): String;
result := '';
BeginPos := Pos('Hrají:', Line);
Delete(Line,1,BeginPos + 5);
HTMLDecode(result);
LineNr : Integer;
Line, Value : String;
BeginPos, EndPos : Integer;
FilmName, FilmAddr, dalsi : String;
LineNr := FindLine('Hledaný výraz: <b>', Page, 0);
if LineNr = -1 then
AnalyzeMoviePage(Address);
LineNr := FindLine('FILMY</td>', Page, 0);
if LineNr = -1 then
ShowMessage('No movie found for this search.'+chr(13)+'Nebyly nalezeny zadne zaznamy.')
LineNr := FindLine('<a href="film.', Page, 0);
if LineNr > -1 then
PickTreeAdd('Filmy: ' + MovieName, '');
BeginPos := Pos('<a href="film',Line);
If BeginPos > 0 Then
EndPos := Pos('" >',Line);
if EndPos = 0 Then EndPos := Length(Line);
FilmAddr := Copy(Line, BeginPos+9, EndPos-BeginPos-9);
HTMLDecode(FilmAddr);
HTMLRemoveTags(FilmAddr);
EndPos := Pos('<br>',Line);
FilmName := Copy(Line, BeginPos, EndPos-BeginPos);
HTMLDecode(FilmName);
HTMLRemoveTags(FilmName);
dalsi := Copy(FilmName,0,25);
if dalsi = '...další nalezené záznamy' then
FilmName := Copy(FilmName,26,Length(FilmName)-25);
if FilmName <> '' then
PickTreeAdd(FilmName, BaseAddress + FilmAddr + '&text=1');
Delete(Line,1,EndPos+3);
until BeginPos <1;
If PickTreeExec(Address) Then
LineNr : Integer;
Line, Value, Value2 : String;
LinePos, BeginPos, EndPos, MidPos, PomPos : Integer;
LineNr := FindLine('<span class="style4"', Page, 0);
if LineNr > -1 then
LinePos := 1;
Line := Page.GetString(LineNr+LinePos);
//prelozeny nazev
HTMLDecode(Line);
HTMLRemoveTags(Line);
Value := Copy(Trim(Line),4,Length(Trim(Line))-3);
//nazev
LinePos := LinePos + 1;
Value2 := '';
BeginPos := Pos('<table cellpadding=',Line);
BeginPos := Pos('<td>',Line);
MidPos := Pos('flag_52.gif',Line);
Line := Copy(Line,BeginPos+4,Length(Line)-(BeginPos+3));
EndPos := Pos('</td>',Line);
if (MidPos < BeginPos) and (MidPos > 0) then
Value := Value + '; ' + Copy(Line, 1, EndPos-1)
Value2 := Value2 + Copy(Line, 1, EndPos-1) + '; ';
until BeginPos < 1;
if Value2 = '' then
Value2 := Value
Value2 := Copy(Value2,1,length(Value2)-2);
SetField(fieldOriginalTitle, Value2);
//kategorie
BeginPos := Pos('<b>',Line);
Line := Copy(Line, BeginPos+3,Length(Line)-(BeginPos-2));
MidPos := Pos('<br>',Line);
EndPos := Pos('</b>',Line);
PomPos := Pos('min</b>',Line);
//existuji oba radky - kategorie i stat,rok,delka
if (MidPos < EndPos) and (MidPos > 0) then
Value := Trim(Copy(Line, 1, MidPos-7));
Value := Trim(Copy(Line, MidPos+4, EndPos-MidPos-4));
RozdelStat(Value);
//existuje jen jeden radek
if (PomPos < EndPos) and (PomPos > 0) then
Value := Trim(Copy(Line, 1, EndPos-1));
RozdelStat(Value);
Value := Trim(Copy(Line, 1, EndPos-7));
SetField(fieldCategory,Value);
Value := GetDirector(Line);
Value := GetActor(Line);
SetField(fieldActors, Value);
// picture
LineNr := FindLine('src="posters/', Page, 0);
if LineNr > -1 then
BeginPos := pos('<img src="posters', Line) + 10;
if BeginPos > 10 then
EndPos := pos('" border="', Line);
Value := BaseAddress + Value;
GetPicture(Value);
// Info
LineNr := FindLine('<B>Obsah/Info:</B>', Page, 0);
if LineNr > -1 then
Value := Page.GetString(LineNr+2);
HTMLDecode(Value);
HTMLRemoveTags(Value);
SetField(fieldDescription, Trim(Value));
// URL
//DisplayResults;
if CheckVersion(3,5,0) then
if Input('Import movie from www.csfd.cz', 'Enter the title of the movie:', MovieName) then
begin AnalyzePage(BaseAddress + 'search.php?search='+UrlEncode(MovieName));
