Willspo Template Upgrade??
I use the willspo template (the xslt template) but i'm not very able to change or to modify it.
With the new amc 3.5 i can't export the ratings value,i can i fix it?
Beside i want to add other voice :
Seen - Not seen (Visto - Non Visto)
Date Added (data di inserimento)
And ,if it's possible, to strech the window so it fit the 1024x768 resolution i have.
At last ,how can i translate it in italian?
PS Sorry for my bad english.
