print more than 1 record per page
sirrock4
Post by sirrock4 »
When I first used the List 1 or List 2 print templates I would see all of my movie files listed with multiple entires per page. Now when I go back to the print preview function I can only get 1 file per page. I have looked for some options to change in the design mode but nothing I change in the settings has been successful so far.
By default these templates print more than 1 movie per page.
You have to select all the movies to print before calling the print window, or select the movies in the "movies" tab of the print window (version 3.4.3) or ajust the "movies to imclude" filter (version 3.5)
