Cannot Add! Help
PhatAzzDan
Cannot Add! Help
Post by PhatAzzDan »
Okay, so maybe I'm not seeing what's wrong here, but I added a total of 119 movies, 117 of which was one day, 2 the next day that i bought. Now, I just bought another movie, but no longer have the option to add. I didn't think that there was a limit to the number of records we could use. Does anyone have a suggestion? Please advise.
Thank you,
Dan
BogdanKa
Post by BogdanKa »
What you mean "can't add a movie"? Disappear icon "Add" on toolbar or don't work "Add movie" from pulldown menu Movie?
If no icon just go to Preferences -> Custom toolbar -> check "Add...".
For second, wait for answer from antp. ;)
There is no real limit (except the size of the available memory), so there is no reason why adding movie would be disabled.
PhatAzzDan
My friggin luck then!
The add file button or icon is grayed out! It's there, but I cannot click on it or use Alt-Ins. I wonder if it has something to do with me restoring my computer to a previous date... i will try to re-install the program. Thanks for the help!
Dan
This button is disabled only if you switched to "grid mode" (F11 in version 3.5, F7 in 3.4.3)
