[REL] Subroutine: The.Mission.[DVD] to The Mission
ABNormal
Post by ABNormal »
I'm trying to make a subroutine to put inside scripts that does this:
from a title like this:
Il.Colore.viola.[XviD-ITA-ENG].avi
changes dots into spaces and removes square brackets with all written inside, having a result like this:
Il Colore viola
Is anyone able to write the/a valid code?
Thank YOU all
ABN
As I said somewhere else, simply use the functions of StringUtils1:
program NewScript;
  StringUtils1;
  s, s2: string;
  s := StringReplace(GetField(fieldOriginalTitle), '.', ' ');
  s2 := TextBefore(s, '[', '');
  if s2 = '' then
    s2 := s;
  SetField(fieldOriginalTitle, s);
ScorEpioN
Post by ScorEpioN »
you could use my script "Update Fields" v10 or next v12
ABNormal
Post by ABNormal »
now i have studied this script.
now i'm changing the MovieName definition (into scripts i use) as:
    MovieName := StringReplace(GetField(fieldTranslatedTitle), '.', ' ');
While pos ('[', MovieName) > 0 Do begin
  MovieName := TextBefore(MovieName, '[', '') + TextAfter(MovieName, ']');
(adding
  StringUtils1;
at the beginning of each script, of course)
solving my little "problem"
i thank you for all your precious helps.
ABN
