Need a PHP Template with SQL support
Bad Joker
Post by Bad Joker »
hey there
can anybody here tell my, how i can create my movie list with php and sql database?
the export shouldn't be the problem, but i don't know how i use sql and php to create my movie list
maybe somebody already has such a template that can be used, would be great to see the source so that we can include it in amc and everyone can use this way ;)
There is a sample PHP file in the "templates" folder. It is in a .zip file ;)
