[REL][US]AnimeNfo.com
Mrknife
Post by Mrknife »
Here is a quick script i wrote.
its pretty sloppy but enjoy.
if there is any suggestions or problems please post them here.
Be gentle, this is my first time.
Mrknife
// GETINFO SCRIPTING
// AnimeNfo (US) By Mrknife
{*  This was slapped together from the script
 *  IMDB that was included with version 3.4.3
 *  !!  Country and Language are always set to Japan/Japanese
 *  !!  Only the First Category will be used
 *  !!  You will always have to select a title, even when the list is only 1 option
 *  Acknoledgements...
 *  Based on the script rewritten for version 3.5  *
 *  Which was based on the script made for         *
 *  version 3.3.x / 3.4.x by                       *
 *  Antoine Potten, Danny Falkov, Kai Blankenhorn, *
 *  lboregard, Ork, Trekkie, Youri Heijnen
program AnimeNfo;
// ***** Here you can change the options of the script *****
function GetOption(OptName: string): Integer;
  case OptName of
    'BatchMode': Result := 0;
          0=Normal working mode, prompts user when needed
          1=Does not display any window, takes the first movie found
    'PopularSearches': Result := 1;
          0=Do not use the popular searches page, directly show full search results
          1=Show popular searches first, I'll click on "Find more" if needed
    'ActorsLayout': Result := 3;
          3=Actors names with character names between parenthesis separated by linebreaks
    'DescriptionSelection': Result := 2;
          0=Take the short summary, from main page (faster)
          1=Show a list of available summaries
          2=Take the longest summary
    'GetTagline': Result := 0;
          0=Do not get tagline
          1=Put it in Description field, before the summary
          2=Put it in the Comment field, before the comments
// Here you can specify which fields can be modified.
// Simply remove a field from the list if it cannot be modified
function CanSetField(fieldID: Integer): Boolean;
  case fieldID of
    fieldNumber,
    fieldMedia,
    fieldMediaType,
    fieldSource,
    fieldDate,
    fieldBorrower,
    fieldRating,
    fieldOriginalTitle,
    fieldTranslatedTitle,
    fieldDirector,
    fieldProducer,
    fieldCountry,
    fieldCategory,
    fieldYear,
    fieldLength,
    fieldActors,
    fieldURL,
    fieldDescription,
    fieldComments,
    fieldVideoFormat,
    fieldVideoBitrate,
    fieldAudioFormat,
    fieldAudioBitrate,
    fieldResolution,
    fieldFrameRate,
    fieldLanguages,
    fieldSubtitles,
    fieldSize,
    fieldDisks:   Result := True;
    Result := False;
  MovieURL: string;
  MovieNumber: string;
  RemainingText: string;
    when calling...     this variable contains...
    TextBefore          the text after SearchText
    TextBetween         the text after AfterText
// ***** Like the Pos function, but returns the last occurence instead of the first one *****
function LastPos(ASearch: string; AText: string): Integer;
  CurPos, PrevPos: Integer;
  PrevPos := 0;
  CurPos := Pos(ASearch, AText);
  while CurPos > 0 do
    if PrevPos = 0 then
      PrevPos := CurPos
      PrevPos := PrevPos + CurPos + Length(ASearch) - 1;
    Delete(AText, 1, CurPos + Length(ASearch) - 1);
  Result := PrevPos;
{    Returns the text before SearchText, but not before BeginLimit (if it is not empty),
    It takes the last occurence of BeginLimit found before the position of SearchText  }
function TextBefore(WholeText: string; SearchText: string; BeginLimit: string): string;
  FoundPos, PrevPos: Integer;
  WorkText: string;
  Result := '';
  FoundPos := Pos(SearchText, WholeText);
  if FoundPos = 0 then
    Exit;
  WorkText := Copy(WholeText, 1, FoundPos - 1);
  RemainingText := Copy(WholeText, FoundPos + Length(SearchText), Length(WholeText));
  if BeginLimit <> '' then
    FoundPos := LastPos(BeginLimit, WorkText);
      Exit
      FoundPos := FoundPos + Length(BeginLimit);
    FoundPos := 1;
  Result := Copy(WorkText, FoundPos, Length(WorkText));
// ***** Returns the text after SearchText *****
function TextAfter(WholeText: string; SearchText: string): string;
  FoundPos: Integer;
  Result := '';
    Exit;
  Result := Copy(WholeText, FoundPos + Length(SearchText), Length(WholeText));
{    Returns the text between BeforeText and AfterText (without these two strings),
     It takes the first AfterText occurence found after the position of BeforeText  }
function TextBetween(WholeText: string; BeforeText: string; AfterText: string): string;
  FoundPos: Integer;
  WorkText: string;
  Result := '';
  FoundPos := Pos(BeforeText, WholeText);
    Exit;
  WorkText := Copy(WholeText, FoundPos + Length(BeforeText), Length(WholeText));
  FoundPos := Pos(AfterText, WorkText);
    Exit;
  Result := Copy(WorkText, 1, FoundPos - 1);
  RemainingText := Copy(WorkText, FoundPos + Length(AfterText), Length(WorkText));
// ***** analyzes the results page that asks to select a movie from a list *****
  PageText: string;
  Value: string;
  PageText := GetPage(Address);
  if pos('<font color=''#FFFFFF''><b> Search Result', PageText) = 0 then
    AnalyzeMoviePage(PageText)
      Value := 'results:';
      if Value <> '' then
        HTMLRemoveTags(Value);
        HTMLDecode(Value);
        PickTreeAdd(Value, '');
      Value := TextBetween(PageText, 'Search Result', 'End Contents');
      PageText := RemainingText;
    until not AddMovieTitles(Value);
    Value := TextBefore(PageText, '"><b>more titles</b></a>', '<a href="');
    if Value <> '' then
      PickTreeMoreLink('http://www.animenfo.com/animetitle' + Value );
      AnalyzeResultsPage(Address);
// ***** adds the titles contained in <ol>'s items *****
  Value: string;
  Address: string;
  Result := False;
  Value := TextBetween(List, 'href=''animetitle', 'html''>');
  Name := TextBetween(List, 'html''>', '</a>');
  List := RemainingText;
  while Value <> '' do
    Address := Value+'html';
    HTMLDecode(Value);
    PickTreeAdd(Name, 'http://www.animenfo.com/animetitle' + Address);
    Result := True;
// ***** analyzes the page containing movie information *****
procedure AnalyzeMoviePage(PageText: string);
  Value, Value2, Value3, FullValue, MovieT, MovieTitle_Html,CHar11 ,SEiyu : string;
  MovieNumber := TextBetween(PageText, '/anime/episode/display.php?id=', '&n=');
  MovieT := TextBetween(PageText, '&n=', '&t=');
  MovieTitle_Html := TextBetween(PageText, '&t=', '''>');
  MovieURL := 'http://www.animenfo.com/animetitle,' + MovieNumber + ',' + MovieT + ',' + MovieTitle_Html + '.html';
  // URL
  if CanSetField(fieldURL) then
    SetField(fieldURL, MovieURL);
  // Original Title & Year
  if CanSetField(fieldOriginalTitle) or CanSetField(fieldYear) then
    Value := TextBetween(PageText, '<title>AnimeNfo.Com : Anime : ', '</title>');
  //  Value2 := TextBefore(Value, ' (', '');
//    Value := RemainingText;
 //   HTMLDecode(Value2);
    Value2 := TextBetween(PageText, 'animebyyear.php?year=', '''>');
      SetField(fieldYear, Value2);
  // Rating
    Value := TextBetween(PageText, 'User Rating</font></td><td valign=''top'' bgcolor=''#F0F0F0''><font class=''DefaultFont''', '/10.0');
    Value2 := TextBetween(Value, '>', '.');
    if StrToInt(Copy(RemainingText, 1, 1), 0) >= 5 then
      Value2 := IntToStr(StrToInt(Value2, 0) + 1);
    SetField(fieldRating, Value2);
  // Picture     NOT WORKING RIGHT NOW
 ImportSmallPicture(PageText);
  // Director
    Value := TextBetween(PageText, 'Studio</font></td>', '<br></font></td></tr>');
    Value2 := TextBefore(Value, '</a>','</script>');
    SetField(fieldProducer, Value2);
  // Actors            working
    SEiyu := 'garbage';
    Value := TextBetween(PageText, 'Seiyuu (Voice Talent)</font>', 'Explanation');
    //SetField(fieldActors, Value);
    if Value <> '' then
      FullValue := '';
            CHar11 := TextBefore(Value, '</a></td><td valign', '>');
            if CHar11 = '' then
            SEiyu := TextBefore(Value, '</a></td><td valign', '>');
            FullValue := FullValue + SEiyu + ' (as ' + CHar11 + ')' + #13#10;
      HTMLRemoveTags(FullValue);
      HTMLDecode(FullValue);
  //Country       Set to Japan
    SetField(fieldCountry, 'Japan');
  //Category      Can only get the First Catagory
    Value := TextBetween(PageText, '<font class=''DefaultFont''>Genres', ', <a');
    Value2 := TextBefore(Value, '</a>','>');
    SetField(fieldCategory, Value2);
  // Language      Set to Japanese
  if CanSetField(fieldLanguages) then
    SetField(fieldLanguages, 'Japanese');
  //Description
  if CanSetField(fieldDescription) then
     Value := TextBetween(PageText, 'Description </b></font>', '</font></td></tr></table><br><table border=');
     Value2 := TextAfter(Value, '<font class=''DefaultFont''>');
     HTMLRemoveTags(Value2);
     HTMLDecode(Value2);
     SetField(fieldDescription, Value2);
  // Comments
    Value := TextBetween(PageText, 'Total Episodes</font></td><td valign=''top'' bgcolor=''#F0F0F0''><font class=''DefaultFont''>', '</font>');
     HTMLDecode(Value);
    SetField(fieldComments, 'Total Episodes: '+Value);
  // Length
  {  Value := TextBetween(PageText, '<b class="ch">Runtime:</b>' + #13#10, ' ');
    if Value <> '' then
      if Pos(':', Value) > 0 then
        SetField(fieldLength, TextAfter(Value, ':'))
        SetField(fieldLength, Value);
  // TagLine
  if GetOption('GetTagline') > 0 then
  {  Value := TextBetween(PageText, 'Tagline:</b>', #13);
    if Pos('<a', Value) > 0 then
      Value := TextBefore(Value, '<a', '');
    HTMLDecode(Value);
    Value := Trim(Value);
    if Value <> '' then
      Value := '"' + Value + '"';
      case GetOption('GetTagline') of
        1:
            SetField(fieldDescription, Value + #13#10 + GetField(fieldDescription));
        2:
            SetField(fieldComments, Value + #13#10 + GetField(fieldComments));
// ***** functions to import the different pictures kinds, depending of the option selected by user *****
function ImportSmallPicture(PageText: string): Boolean;
  Value: string;
  Result := False;
  Value := TextBetween(PageText, '<img border=''0'' ', 'font class=''DefaultFont''>Title');
  Value := TextBetween(Value, 'Src=''', ''' width');
  if Value <> '' then
    GetPicture(Value, False);
    Result := True;
// ***** beginning of the program *****
  if CheckVersion(3,4,3) then
      if not Input('AnimeNfo Import', 'Enter the name of the anime Series :', MovieName) then
        Exit;
    if MovieName <> '' then
      if Pos('AnimeNfo.com', MovieName) > 0 then
        AnalyzeResultsPage(MovieName)
        MovieName := StringReplace(MovieName, '&', 'and');
          AnalyzeResultsPage('http://www.animenfo.com/search.php?query='+UrlEncode(MovieName)+'&action=Go&queryin=anime_titles&option=keywords')
      DisplayResults;
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.4.3)');
Thanks.
I added
 tags rather than [color] tags since it allows to copy the script without loosing the formatting/indents ;)
thank you thank you thank you!
Thx
:cool: Fantasic! Just what I was looking for. Thanks!!!
SublicK
Post by SublicK »
Hello,
Thanks for your work on this script. One question though... When I run it, it gives an error saying "Duplicate Identifier" on line 23. Seems to be the set options function. Any idea what's causing this? I'm running 3.5.0 RC2
This is a script made for AMC 3.4.3 with an emulation of function system of AMC 3.5 (that was made for the IMDB script but that is quite useless here).
In the version 3.5 final that should be released very soon I'll include a converted version of this script.
why not all? :??:
ok. I modified script independently (sorry for my english :D )
  //Category      Can get the All Catagory ;)
    Value := TextBetween(PageText, ',"', '")');
      delete(Value, (pos('",', Value)+2), (pos(',"', Value)-pos('",', Value)));
      delete(Value, pos('"', Value), 1);
    until(pos('"', Value)=0);
this is the modified fragment from the script with AMC ver.3.5
P.S: thx for original script :grinking:
nightanole
Post by nightanole »
Does this still work? I cant get the one that came with 3.5.0 to work. I tryed this script and it errors out.
