[ENG]
Hello,
I'm looking for a software (free or open-source) to manage my personal library. My needs are differents from a public library, so PhpMyBlibli does not match it.
Here is a short list of my needs:
- View of the cover of the books
- Manage of some category for the books
- Manage the table of content for each book
- Do some search in the books and/or table of content of the books
- Import data from CVS file including table of content (I've got already more than 10,000 lines of table of content)
- import data from the web (like Amazon) of a book (cover, title, summary ....) by using the title of the ISBN number.
I'll try to explain a little bit more my needs.
I'm a fan of aircraft, and I've got hundreds of books about it.
My goal is to put my whole collection of book in a software in order to find something when I need to.
When I want to find something on the Concorde for example, I want to have all the book and all the page in the books that speak about it. That's why I need to manage the table of content.
I need also to create some caterogy inside the table of content, in order to find the Boeing 747 reference, but also all the plane of Boeing too.
Because i've got a lot of books, the possibility to import the data of it from the net (Amazon.fr or .com) is important, because it can save to me a lot of time.
I also need to import data from csv file, including the table of content. I've already something like 10,000 lines of content in an access database, and I don't want to loose it.
Also when I want to add a new table of content of a book, I scan the index of the book, then I use some OCR software, and I correct some errors by hand. At the end I've got a CSV file. That's also why I need to import CSV files.
For the moment, the only softwares that can help was BookCAT and AVCataloger. But they are commercial ones, and I only evaluate it. Besides that, their interface where not user frendly at all....
If anybody have ever heard something about this kind of software, please help me ....
Thanks to all,
Calimero
[FR]
Je recherche un logiciel de gestion de bibliotheque personnelle. Attention, mon besoin est différent de celui d'une bibliotheque publique (type PhpMyBibli).
Les fonctionalités dont j'ai besoin seraient:
- Affichage de la couverture du livre
- Gestion de catégorie
- Gestion des sommaire et/ou table des matière d'un ouvrage
- Recherche dans le table des matière
- importation de données de type CSV (j'ai déja plus de 10 000 lignes d'index d'ouvrage déjaà saisie)
- possibilité de récupérer depuis des site commerciaux les infos et jacquette des livres (amazon et cie...) via le titre ou le numéro ISBN.
Je vais essayer d'expliciter un peu mieux mon besoin.
Je suis un fan d'aéronautique et je possède des centaines d'ouvrages sur la question.
Mon objectif est de recensé ces ouvrages dans un logiciel, mais aussi les tables des matières de ces ouvrages.
Ainsi lorsque je recherche des informations sur le Concore par exemple, je veux pouvoir avoir la liste des ouvrages où il en est question avec les numéros de page et éventuellement le volume s'il s'agit d'une encyclopédie.
J'ai aussi besoin de catégoriser les tables des matières de manière par exemple à classer les reférences des avions par pays et constructeur. Ainsi je peux vouloir sortir toutes les références des avions d'Airbus Industrie dans mes ouvrages.
Comme j'ai un grand nombre d'ouvrages, le fait de pouvoir importer depuis le net les infos de base automatiquement comme le titre, l'éditeur, la couverture m'aiderait pas mal.
Ensuite, il faut que je puisse importer des données depuis un format de type csv. Pourquoi cela me direz-vous?
Tout d'abord parce que j'ai déja quelques dizaines d'ouvrages déjà présent dans une base access personnelle avec des milliers de lignes d'index. Franchement je ne me vois pas recommencer.
Ensuite parceque pour ajouter des index sur des gros ouvrages de type enclyclopédie je scane les index et je passe un coup d'OCR puis je fignole à la main pour avoir un fichier csv. C'est beaucoup plus rapide que de rentrée 10 000 lignes d'index sur une encyclopédie à la main !
j'ai cru voir qu'il exitait des script permettant d'importer des données depuis amazon, et donc de gerer des livres, mais quid de l'importation depuis un fichier csv et de la gestion des tables des matières...
Merci de votre aide et de vos réponses
Calimero
[EN+FR] Manage a personal library
J'ai trouvé une partie de ce que je cherchais avec les scripts et mod développé par André Ratté et Willems Olivier
C'est déja beaucoup, cependant il me manque encore le principal, c'est la gestion des tables des matières.
En effet j'ai besoin de quelque chose de plus souple que celle proposée par le mod d'André Ratté. Sur un livre je veux pouvoir avoir n ligne d'index et faire des recherche dessus.
ceci dit c'est déjà pas mal et je remercie tout ceux qui ont travailler sur ce sujet.
Encore quelques efforts et ec sera parfait
