Request for the HTML Export
Bad Joker
Post by Bad Joker »
hey antoine
i have a little request for the html export
for users with big movie lists (like me ;) ), let's say 300+ movies, the html tables are not that good!
because when you load the html file from the web server, it takes some more seconds than usual, because the browser only shows the content of the table after he had loaded the whole table.
for that i have a request:
is it possible to split the table into 25 tables each with movies from a specific letter. so that you got tables with movies beginning with a, b, c....,z + # (numbers and signs)?
this would be much better, because the files would show during the loading process the first tables until the others are loaded ;)
is this possible to add such a feature to the html export?
this would require a new item like $$ITEM_TITLE_BEGIN and $$ITEM_TITLE_END
then i could create a table title part which contains the letter (all movies with "a", "b"...) and the table part as it is now, just the export knows, now only all movies beginnig with "a"...
i hope you got what i mean
second request is just a reminder:
add the possibility to save a url for the picture in the db and then the flatrate users can just load the picture from the web and also i can export that link into my online movie list ;)
btw, check out my movies list, then you know why i posted this request:
http://kickme.to/badjoker
thx
bad joker :cool: [/b]
For these advanced export features, I will put a kind of scripting export in the version 4, in addition of the current basic export.
The image link idea has already been submited few times, I plan to add that in the next version too ;)
bogdan
Post by bogdan »
When do you think version 4.0 will be ready ? We can hardly wait ! Keep up the good work !
Not before few months
I haven't started working on it yet, and I'll not do that before few weeks. The problem is also that I usually can do that only on weekends, so it will require some time :/
