[REQ] Amazon.de DVD Cover Import
Koprom
Post by Koprom »
Hi all,
the included amazon.de cover import script doesnt't work anymore, it just imports a white picture. Could someone please correct this?
Thank you
I thought it was only designed for that... :??: (designed to only import large picture and nothing else)
it should import a picture, but not a white picture
Sorry, I did not see the word "white" in your post :D I thought that you were complaining about the fact that it imports a picture and no other info.
The script was updated recently, check that you have the latest one:
viewtopic.php?t=1892
seems like the script imports white pictures just with some movies. others work perfectly
