Extra field for quality
subspawn
Post by subspawn »
First of all I'd like to say Ant Movie Catalogs is one of the best I've ever worked and experimented with.
I want to permanently convert my eXtreme Movie Manager database to Ant's one but I've added in EMM a comment in Media Notes for all my movies. A so called quality rating of a movie based upon the results of a program called DRF Analyser.
DRF Analyser gives an objective view of the quality of a movie. For instance a DRF rating of 2.8 or lower symbols really good and very fine picture quality if that is in combination with a decent resolution. This way it's easy to tell which rips are good and which aren't without having to see them.
I was wondering if it would be possible to add an extra field in Ant Movie Catalog where DRF rating could be placed (and even better would be integration of code from Analyser DRF to analyse movies automatically but I think this would be a dream ;))
I hope perhaps the extra field is possible or if need be just name it "media notes" or something where we can place misc information about the movie that's of importance to us.
In version 4 I'll add several missing fields, but this won't be in a very near future.
You have to use one of the others fields until then ;)
