Authors=japg2000 (japg2000@terra.es)
Title=CaratulasDeCine
Description=Picture importation script for www.caratulasdecine.com
Site=www.caratulasdecine.com
Language=ES
Version=1.1
Requires=3.5.0
Comments=
program CaratulasdecineImport;
Title: string;
result := -1;
if StartAt < 0 then
StartAt := 0;
result := i;
result := S;
while Pos(CR, result) = 1 do
function CadenaEntre(var S: string; StartTag: string; EndTag: string): string;
InicioPos: Integer;
InicioPos := Pos(StartTag, S);
Delete(S, 1, InicioPos + Length(StartTag) - 1);
InicioPos := Pos(EndTag, S);
result := copy(S, 1, InicioPos - 1);
Delete(S, 1, InicioPos + 1);
function PreparaTitulo(T: string): string;
result := AnsiLowerCase(T);
HTMLDecode(result);
result := StringReplace(result, chr(146), '');
result := StringReplace(result, chr(39), '');
result := StringReplace(result, '´', '');
result := StringReplace(result, '`', '');
result := StringReplace(result, '"', '');
result := StringReplace(result, '¿', '');
result := StringReplace(result, '?', '');
result := StringReplace(result, '¡', '');
result := StringReplace(result, '!', '');
result := StringReplace(result, '.', '');
result := StringReplace(result, ',', '');
result := StringReplace(result, ':', '');
result := StringReplace(result, ';', '');
result := StringReplace(result, '-', '');
result := StringReplace(result, '/', '');
result := StringReplace(result, '\', '');
result := StringReplace(result, 'á', 'a');
result := StringReplace(result, 'é', 'e');
result := StringReplace(result, 'í', 'i');
result := StringReplace(result, 'ó', 'o');
result := StringReplace(result, 'ú', 'u');
result := StringReplace(result, 'ü', 'u');
result := StringReplace(result, 'ñ', 'n');
function GetCaratulasDeCineDir(MovieTitle: string): string;
PageOfLetter: Array of string;
C: Char;
Index: Integer;
Setarraylength(PageOfLetter,36);
PageOfLetter[0]:='0_9'; PageOfLetter[1]:='0_9'; PageOfLetter[2]:='0_9'; PageOfLetter[3]:='0_9';
PageOfLetter[4]:='0_9'; PageOfLetter[5]:='0_9'; PageOfLetter[6]:='0_9'; PageOfLetter[7]:='0_9';
PageOfLetter[8]:='0_9'; PageOfLetter[9]:='0_9'; PageOfLetter[10]:='a'; PageOfLetter[11]:='b';
PageOfLetter[12]:='c'; PageOfLetter[13]:='d'; PageOfLetter[14]:='e'; PageOfLetter[15]:='f_h';
PageOfLetter[16]:='f_h'; PageOfLetter[17]:='f_h'; PageOfLetter[18]:='i_k'; PageOfLetter[19]:='i_k';
PageOfLetter[20]:='i_k'; PageOfLetter[21]:='l'; PageOfLetter[22]:='m_n'; PageOfLetter[23]:='m_n';
PageOfLetter[24]:='o_q'; PageOfLetter[25]:='o_q'; PageOfLetter[26]:='o_q'; PageOfLetter[27]:='r_s';
PageOfLetter[28]:='r_s'; PageOfLetter[29]:='t_z'; PageOfLetter[30]:='t_z'; PageOfLetter[31]:='t_z';
PageOfLetter[32]:='t_z'; PageOfLetter[33]:='t_z'; PageOfLetter[34]:='t_z'; PageOfLetter[35]:='t_z';
C := copy(MovieTitle, 1, 1);
if (C >= '0') and (C <= '9') then
Index := Ord(C) - Ord('0');
Index := 10 + Ord(C) - Ord('a');
result:='http://www.caratulasdecine.com/' + PageOfLetter[Index] + '.htm';
procedure AnalyzePageCaratulasDeCine(PageDir: string);
CaratulasdecinePage, MoviePage: TStringList;
MovieDir, Line, LineTmp: string;
Encontrado, Salir, BeginPos, EndPos, LineNr, LineMov: Integer;
CaratulasdecinePage := TStringList.Create;
CaratulasdecinePage.Text := GetPage(PageDir);
LineNr := FindLine('</big></big></big></big></big></big>', CaratulasdecinePage, 0);
LineNr := LineNr + 1;
Line := CaratulasdecinePage.GetString(LineNr);
Line := EliminaInicio(Line, ' ');
Salir := 0;
Encontrado := 0;
while (Pos('<br>', Line) = 0) and (Pos('</td>', Line) = 0) and (LineNr < 1000) do
if copy(Line, Length(Line), 1) <> ' ' then
Line := Line + ' ';
LineTmp := CaratulasdecinePage.GetString(LineNr);
LineTmp := EliminaInicio(LineTmp, ' ');
Line := Line + LineTmp;
if Pos('</td>', Line) > 0 then
Salir := 1;
if Pos('<a class="A" href="', Line) > 0 then
MovieDir := 'http://www.caratulasdecine.com/' + CadenaEntre(Line, '<a class="A" href="', '">');
MovieDir := Line;
MovieDir := CadenaEntre(MovieDir, '<a href="', 'class="A">');
while Pos('<a href="', MovieDir) > 0 do
Line := CadenaEntre(Line, '', '<');
Line := PreparaTitulo(Line);
if Pos(Title, Line) > 0 then
MoviePage := TStringList.Create;
MoviePage.Text := GetPage(MovieDir);
LineMov := FindLine('<p align="center"><img src="', MoviePage, 0);
Line := MoviePage.GetString(LineMov);
Line := CadenaEntre(Line, '<p align="center"><img src="', '" ');
Line := EliminaInicio(Line, '../');
GetPicture('http://www.caratulasdecine.com/' + Line);
Salir := 1;
Encontrado := 1;
if LineNr > 1000 then
Salir := 1;
until Salir = 1;
if (Encontrado <> 1) then
ShowMessage('Titulo ' + Title + ' no encontrado en ' + PageDir)
if CheckVersion(3,5,0) then
Title := GetField(fieldTranslatedTitle);
if Title = '' then Title := GetField(fieldOriginalTitle);
Title := PreparaTitulo(Title);
Input('Importar de caratulasdecine.com', 'Por favor, introduce el titulo:', Title);
AnalyzePageCaratulasDeCine(GetCaratulasDeCineDir(Title));
ShowMessage('Este script necesita una versión superior de Ant Movie Catalog (al menos la version 3.5.0)');
