Output to HTML ($$ITEM_RATING format)
de-37091
Post by de-37091 »
Hi
The tag $$ITEM_RATING is not 0 to 10 (i've read it in help-file), so it's 0.0 to 10.0.
The file are appr0 to appr10
Can you correct this in the code?
What do you mean? What has to be corrected?
If you want to not have the decimals there is an option for that in the Preferences. You can also rename your files to appr0.0 to appr10.0 :p
