Pictures
You have choice to store them in a separate folder or into the catalog file.
If you use .xml instead of .amc file format, they are automatically stored as separated file. If you use .amc file format it depends how you add them and the options that you selected in the preferences window.
Currently it is not possible to link to internet.
