IMDB script large picture import is not working
stalemate
Post by stalemate »
i'm using version 3.5 RC3. imdb script is importing small pictures (%90 percent success) and rarely is importing large pictures. (%10 percent success) but amazon script always imports large pictures. could you merge these two? please don't create a script that search large picture in imdb, amazon or himalayas.
here is IMDB script:
Authors=Antoine Potten
Title=IMDB
Description=Import data & picture from IMDB (optional image from Amazon)
Site=us.imdb.com
Language=EN
Version=1.0
Requires=3.5.0
Comments=Based on the script made for version 3.x by Antoine Potten, Danny Falkov, Kai Blankenhorn, lboregard, Ork, Trekkie, Youri Heijnen
ImageKind=0|1|0=No image|1=IMDB small image, from the main movie page|2=IMDB large image if found easily, else small image|3=First search for Amazon large image, then IMDB large one, then IMDB small image if other failed|4=First search for Amazon large image, then directly take IMDB small image if the first one failed|5=IMDB large image if found easily, else search for Amazon large image, then take IMDB small image if others failed
BatchMode=0|0|0=Normal working mode, prompts user when needed|1=Does not display any window, takes the first movie found|2=Same as 1, but it uses the URL field if available to update movie information
PopularSearches=1|1|0=Do not use the popular searches page, directly show full search results|1=Show popular searches first, I'll click on "Find more" if needed
ActorsLayout=3|0|0=Only actor names, separated by commas|1=Only actor names, separated by linebreaks|2=Actors names with character names between parenthesis separated by commas|3=Actors names with character names between parenthesis separated by linebreaks|4=Actor names like on IMDB page, with "...." and separated by linebreaks
MultipleValuesCountry=1|0|0=Only take first value for Country|1=Take full list, separated by commas|2=Take full list, separated by slashes
MultipleValuesCategory=1|0|0=Only take first value for Category|1=Take full list, separated by commas|2=Take full list, separated by slashes
MultipleValuesLanguages=1|0|0=Only take first value for Languages|1=Take full list, separated by commas|2=Take full list, separated by slashes
DescriptionSelection=0|1|0=Take the short summary, from main page (faster)|1=Show a list of available summaries|2=Take the longest summary
GetTagline=1|0|0=Do not get tagline|1=Put it in Description field, before the summary|2=Put it in the Comment field, before the comments
program IMDB;
  StringUtils1;
  MovieURL: string;
  MovieNumber: string;
// ***** analyzes the results page that asks to select a movie from a list *****
  PageText: string;
  Value: string;
  PageText := GetPage(Address);
  if pos('<title>IMDb', PageText) = 0 then
    AnalyzeMoviePage(PageText)
        ShowMessage('No movie found for this search');
      Exit;
      Value := TextBefore(PageText, '<ol>', '<b>');
      if Value <> '' then
        HTMLRemoveTags(Value);
        HTMLDecode(Value);
        PickTreeAdd(Value, '');
      Value := TextBetween(PageText, '<ol>', '</ol>');
      PageText := RemainingText;
    until not AddMovieTitles(Value);
    Value := TextBefore(PageText, '"><b>more titles</b></a>', '<a href="');
    if Value <> '' then
      PickTreeMoreLink('http://us.imdb.com' + Value);
      AnalyzeResultsPage(Address);
// ***** adds the titles contained in <ol>'s items *****
  Value: string;
  Address: string;
  Result := False;
  Value := TextBetween(List, '<li>', '</li>');
  List := RemainingText;
  while Value <> '' do
    Address := TextBetween(Value, '<a href="', '">');
    HTMLDecode(Value);
    PickTreeAdd(Value, 'http://us.imdb.com' + Address);
    Result := True;
// ***** analyzes the page containing movie information *****
procedure AnalyzeMoviePage(PageText: string);
  Value, Value2, Value3, FullValue: string;
  MovieNumber := TextBetween(PageText, '<input type="hidden" name="arg" value="', '"><input');
  MovieURL := 'http://us.imdb.com/title/tt' + MovieNumber;
  // URL
  if CanSetField(fieldURL) then
    SetField(fieldURL, MovieURL);
  // Original Title & Year
  if CanSetField(fieldOriginalTitle) or CanSetField(fieldYear) then
    Value := TextBetween(PageText, '<title>', '</title>');
    Value2 := TextBefore(Value, ' (', '');
    Value := RemainingText;
    HTMLDecode(Value2);
      SetField(fieldOriginalTitle, Value2);
    if Pos('/', Value) > 0 then
      Value2 := TextBefore(Value, '/', '')
      Value2 := TextBefore(Value, ')', '');
      SetField(fieldYear, Value2);
  // Rating
    Value := TextBetween(PageText, '/rating-stars/', '/rating-vote/');
    SetField(fieldRating, TextBetween(Value, '<b>', '/'));
  // Picture
  if CanSetPicture then
    case GetOption('ImageKind') of
      1:  ImportSmallPicture(PageText);
      2:  if not ImportLargePicture('http://us.imdb.com/gallery/ss/' + MovieNumber) then
      3:  if not ImportAmazonPicture(PageText) then
      4:  if not ImportAmazonPicture(PageText) then
      5:  if not ImportLargePicture('http://us.imdb.com/gallery/ss/' + MovieNumber) then
  // Director
    Value := TextBetween(PageText, '<b class="blackcatheader">Directed by</b><br>', '<br>' + #13);
    Value := StringReplace(TextAfter(Value, '">'), '<br>', ', ');
    HTMLDecode(Value);
  // Actors
    Value := TextBetween(PageText, 'ast overview', '</div>');
    if Value = '' then
      Value := TextBetween(PageText, 'redited cast', '</div>');
    if Value <> '' then
      Value := TextAfter(Value, '</tr> ');
      FullValue := '';
      case GetOption('ActorsLayout') of
        0, 1:
          while Pos('<tr>', Value) > 0 do
            Value2 := TextBetween(Value, '<tr>', '</tr>');
            if Pos('<a href="fullcredits">(more)</a>', Value2) > 0 then
            if FullValue <> '' then
            FullValue := FullValue + TextBefore(Value2, '</td>', '');
        2, 3:
            Value2 := TextBetween(RemainingText, '<td valign="top">', '</td>');
            if Value2 <> '' then
              FullValue := FullValue + ' (as ' + Value2 + ')';
        4:
            FullValue := TextBefore(Value, '</tr><tr><td colspan="2">', '');
            if FullValue = '' then
              FullValue := Value;
            FullValue := StringReplace(FullValue, '</tr>', #13#10);
      HTMLRemoveTags(FullValue);
      HTMLDecode(FullValue);
        0, 2:
          FullValue := StringReplace(FullValue, #13#10, ', ');
  //Country
    SetField(fieldCountry, ImportList(PageText, GetOption('MultipleValuesCountry'), '/Countries/'));
  //Category
    SetField(fieldCategory, ImportList(PageText, GetOption('MultipleValuesCategory'), '/Genres/'));
  // Language
  if CanSetField(fieldLanguages) then
    SetField(fieldLanguages, ImportList(PageText, GetOption('MultipleValuesLanguages'), '/Languages/'));
  //Description
  if CanSetField(fieldDescription) then
    Value := TextBetween(PageText, '<b class="ch">Plot Outline:</b>', '<br><br>');
    if Value = '' then
      Value := TextBetween(PageText, '<b class="ch">Plot Summary:</b>', '<br><br>');
    if Value <> '' then
      SetField(fieldDescription, ImportSummary(Value));
  // Comments
    Value := TextAfter(PageText, '/comments">');
    if Value <> '' then
      Value := TextBetween(Value, '<p>', '</p>');
      Value := StringReplace(Value, #13#10, ' ');
      HTMLDecode(Value);
      Value := Trim(Value);
      while Pos('  ', Value) > 0 do
      while Pos(#13#10, Value) = 1 do
        Delete(Value, 1, 2);
  // Length
    Value := TextBetween(PageText, '<b class="ch">Runtime:</b>' + #13#10, ' ');
    if Value <> '' then
      if Pos(':', Value) > 0 then
        SetField(fieldLength, TextAfter(Value, ':'))
        SetField(fieldLength, Value);
  // TagLine
  if GetOption('GetTagline') > 0 then
    Value := TextBetween(PageText, 'Tagline:</b>', #13);
    if Pos('<a', Value) > 0 then
      Value := TextBefore(Value, '<a', '');
    HTMLDecode(Value);
    if Value <> '' then
      Value := '"' + Value + '"';
      case GetOption('GetTagline') of
        1:
            SetField(fieldDescription, Value + #13#10 + GetField(fieldDescription));
        2:
            SetField(fieldComments, Value + #13#10 + GetField(fieldComments));
// ***** Imports lists like Genre, Country, etc. depending of the selected option *****
function ImportList(PageText: string; MultipleValues: Integer; StartTag: string): string;
  Value, Value2: string;
  if MultipleValues = 0 then
    Value := TextBetween(PageText, StartTag, '</a>');
    Value2 := TextAfter(Value, '">');
    Value := TextBetween(PageText, StartTag, #13#10);
    Value2 := TextBefore(Value, ' <a href="/rg', '');
      Value := Value2;
    HTMLRemoveTags(Value2);
    if MultipleValues = 1 then
      Value2 := StringReplace(Value2, ' / ', ', ');
  HTMLDecode(Value2);
  Result := Value2;
// ***** functions to import the different pictures kinds, depending of the option selected by user *****
function ImportSmallPicture(PageText: string): Boolean;
  Value: string;
  Result := False;
  Value := TextBetween(PageText, '<img border="0" alt="cover" src="', '"');
  if Value <> '' then
    GetPicture(Value);
    Result := True;
function ImportLargePicture(Address: string): Boolean;
  Result := True;
  Value := GetPage(Address);
  if SearchForLargePicture(Value, 'Onesheet_text', False) then
    Exit;
  if SearchForLargePicture(Value, 'Onesheet', False) then
    Exit;
  if SearchForLargePicture(Value, 'poster', False) then
    Exit;
  if SearchForLargePicture(Value, 'keyart01', False) then
    Exit;
  if SearchForLargePicture(Value, 'usposter', False) then
    Exit;
  if SearchForLargePicture(Value, 'text', True) then
    Exit;
  if SearchForLargePicture(Value, 'pos01', True) then
    Exit;
  if SearchForLargePicture(Value, 'KeyArt', True) then
    Exit;
  if SearchForLargePicture(Value, 'heet', True) then // Sheet & Onesheet
    Exit;
  if SearchForLargePicture(Value, 'OneSheetv2', True) then
    Exit;
  if SearchForLargePicture(Value, 'artwork', True) then
    Exit;
  Address := TextBetween(Value, 'There are ' + #13#10 + '<a href="', '">');
  if Address <> '' then
    Result := ImportLargePicture('http://us.imdb.com' + Address)
    Result := False;
function SearchForLargePicture(PageText: string; Name: string; PartialName: Boolean): Boolean;
  Value: string;
  Result := False;
  if PartialName then
    Value := TextBefore(PageText, Name + '.jpg', '/');
    if Value = '' then
      Exit
      Name := Value + Name;
  Value := TextBefore(PageText, 'th-' + Name + '.jpg', 'src="');
  if Value <> '' then
    GetPicture(Value + Name + '.jpg');
    Result := True;
function ImportAmazonPicture(PageText: string): Boolean;
  Result := False;
  Value := TextBefore(PageText, '" title="DVD available', '<a href="');
  if Value = '' then
    Exit;
  PageText := GetPage('http://us.imdb.com' + Value);
  if Pos('unable to find exact matches', PageText) > 0 then
    Exit;
  if Pos('You may also be interested in these items...', PageText) > 0 then
    PageText := TextBefore(PageText, 'You may also be interested in these items...', '');
  Value := TextBefore(PageText, 'TZZZZZZZ.jpg', '<img src="');
  if Value = '' then
    Value := TextBefore(PageText, 'THUMBZZZ.jpg', '<img src="');
  if Value <> '' then
    GetPicture(Value + 'LZZZZZZZ.jpg');
    Result := True;
// ***** Gets summaries for the movie, based on the plot outline given in parameter (that contains the URL to more summaries) *****
function ImportSummary(PlotText: string): string;
  Address, Value, Value2, PageText, Longest: string;
  Address := TextBetween(PlotText, '<a href="/rg/title-tease/plotsummary', '">(more)</a>');
  if (Address = '') or (GetOption('DescriptionSelection') = 0) then
    Result := Trim(TextBefore(PlotText, '<a href="/rg', ''));
    if Result = '' then
      Result := Trim(PlotText);
    HTMLRemoveTags(Result);
    HTMLDecode(Result);
    PageText := GetPage('http://us.imdb.com/rg/title-tease/plotsummary' + Address);
    PickListClear;
    Longest := '';
    Value := TextBetween(PageText, '<p class="plotpar">', '</p>');
      HTMLDecode(Value);
      if Length(Value) > Length(Longest) then
        Longest := Value;
      PickListAdd(Trim(Value));
    if (GetOption('BatchMode') > 0) or (GetOption('DescriptionSelection') = 2) then
      Result := Longest
      if not PickListExec('Select a description for "' + GetField(fieldOriginalTitle) + '"', Result) then
        Result := '';
// ***** beginning of the program *****
  if CheckVersion(3,5,0) then
    MovieName := '';
    if GetOption('BatchMode') = 2 then
      MovieName := GetField(fieldURL);
      if Pos('imdb.com', MovieName) = 0 then
        MovieName := '';
      if not Input('IMDB Import', 'Enter the title or the IMDB URL of the movie:', MovieName) then
        Exit;
      Sleep(500);
    if MovieName <> '' then
      if Pos('imdb.com', MovieName) > 0 then
        AnalyzeResultsPage(MovieName)
        MovieName := StringReplace(MovieName, '&', 'and');
        if (GetOption('BatchMode') > 0) or (GetOption('PopularSearches') = 1) then
          AnalyzeResultsPage('http://us.imdb.com/find?tt=1;q=' + UrlEncode(MovieName))
          AnalyzeResultsPage('http://us.imdb.com/find?more=tt;q=' + UrlEncode(MovieName));
and Amazon script (it's better if you just leave the picture section alone, IMDB script can handle URL, director, etc)
Authors=polnjumen (polnjumen@yahoo.com)
Title=Amazon
Description=Import picture & editorial review from Amazon
Site=www.amazon.com
Language=EN
Version=1.0
Requires=3.5.0
Comments=Based on the script made for version 3.4.0 by facts (jfacts1731@yahoo.com)
GetReview=2|1|0=Do not get Editorial Review|1=Save Editorial Review into Description field|2=Save Editorial Review into Comment field
program Amazon;
  StringUtils1;
  AmazonPage: TStringList;
  THolder, MovieName : string;
  LineNr, I: Integer;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
function GetToken(aString, SepChar: String; TokenNum: Integer):String;
   Token     : string;
   StrLen    : Integer;
   TNum      : Integer;
   TEnd      : Integer;
     StrLen := Length(aString);
     TNum   := 1;
     TEnd   := StrLen;
     while ((TNum <= TokenNum) and (TEnd <> 0)) do
          TEnd := Pos(SepChar,aString);
          if TEnd <> 0 then
               Token := Copy(aString,1,TEnd-1);
               Delete(aString,1,TEnd);
               TNum := TNum + 1;
               Token := aString;
     if TNum >= TokenNum then
          GetToken := Token;
          GetToken := '';
function AsinParse(Line : string): string;
  Result := GetToken(GetToken(Line,'.',2),Chr(34),1);
// ***** analyze the page containing movie information *****
procedure AnalyzeMoviePage(AsinNr: string);
  MovieURL, PageText, Value, Value2: string;
  LP: integer;
  GetPicture('http://images.amazon.com/images/P/' + AsinNr + '.01.LZZZZZZZ.jpg');
  MovieURL := 'http://www.amazon.com/exec/obidos/tg/detail/-/' + AsinNr + '/';
  PageText := GetPage(MovieURL);
  // URL
  // DVD Title & Year
    LP := LastPos('(', Value);
    Value2 := Copy(Value, LastPos('(', Value) + 1, 4);
    Value2 := TextBetween(Value, 'Amazon.com: DVD: ',' ('+ Value2);
    HTMLDecode(Value2);
  //Editorial Review
  if GetOption('GetReview') > 0 then
    Value := TextAfter(PageText, '<a name="amzn-reviews">');
    if Value <> '' then
      Value := TextBetween(Value, '<b class=h1>Editorial Reviews</b>', '<a name="cust-reviews-section">');
      HTMLDecode(Value);
      case GetOption('GetReview') of
        1:
        2:
  // Director
    Value := TextBetween(PageText, '<b>Director:</b>','</a><br>');
    HTMLDecode(Value);
    SetField(fieldDirector, Trim(Value));
  // Producer
    Value := TextBetween(PageText, '<b>Studio:</b>','<li>');
    Value := StringReplace(Value, #13#10, '');
    SetField(fieldProducer, Trim(Value));
  // Length
    Value := TextBetween(PageText, '<b>Run Time:</b>','<br>');
    SetField(fieldLength, Trim(Value));
    AmazonPage := TStringList.Create;
    AmazonPage.Text := GetPage('http://www.amazon.com/exec/obidos/search-handle-url/index=dvd&field-title=' + StringReplace(UrlEncode(GetField(fieldOriginalTitle)),'+', '%20'));
    if FindLine('unable to find exact matches',AmazonPage,1) <> -1 then
        ShowMessage('Movie "' + GetField(fieldOriginalTitle) + '" not found.');
    if FindLine('Amazon.com: DVD:',AmazonPage,1) <> -1 then
        LineNr := FindLine('<input type="hidden" name="asin.',AmazonPage,1);
        THolder := AsinParse(AmazonPage.Getstring(LineNr));
        AnalyzeMoviePage(THolder);
      if (FindLine('Below are results for',AmazonPage,1) <> -1) OR (FindLine('All results',AmazonPage,1) <> -1) OR (FindLine('Most popular results for',AmazonPage,1) <> -1) OR (FindLine('Results for',AmazonPage,1) <> -1) then
          i := 1;
          PickTreeAdd('Movies','');
          while (i <= AmazonPage.Count-1) do
              THolder := AmazonPage.GetString(i);
              HTMLRemoveTags(THolder);
              if (Pos('/exec/obidos/ASIN/',AmazonPage.GetString(i)) <> 0) and (THolder <> '') and (Pos('Buy new',AmazonPage.GetString(i)) = 0) and (Pos('Used & new from',AmazonPage.GetString(i)) = 0) and (Pos('THUMBZZZ',AmazonPage.GetString(i)) = 0) then
                PickTreeAdd(THolder,GetToken(AmazonPage.GetString(i),'/',5));
              if (Pos('/exec/obidos/tg/detail/',AmazonPage.GetString(i)) <> 0) and (THolder <> '') and (Pos('Buy new',AmazonPage.GetString(i)) = 0) and (Pos('Used & new from',AmazonPage.GetString(i)) = 0) and (Pos('THUMBZZZ',AmazonPage.GetString(i)) = 0) and (Pos('http://www.amazon.com',AmazonPage.GetString(i)) = 0) and (Pos('In-store Pickup',AmazonPage.GetString(i)) = 0) then
                PickTreeAdd(THolder,GetToken(AmazonPage.GetString(i),'/',7));
              i := i + 1;
          if PickTreeExec(THolder) then
why do you post these scripts here :hum: everybody has them since they come with the program
