Bug in new version?
billynjad
Bug in new version?
Post by billynjad »
When I try to save a movie such as "The Butterfly Effect" as "Butterfly Effect, The" the program will not put it in alphabetic order. I t will only show up at the top of my list no matter what I try. The old version saved the movies as the default , the way I am trying to do. Otherwise you end up with a good portion of your movies started under "The ......"
You mean using the "Formatted title" option ?
Or is it simply a movie coming from IMDB ?
It seems that in some cases IMDB now puts the "The" in front of the movie, but this can be changed by using the options in Tools -> Preferences -> Formatted title.
billynjad
Post by billynjad »
That was it...... I guess it was the default before and I didn't need to do it.
Thanks!
Before it was not the default, but IMDB was sending the titles with the "The" at the end, so it was not useful to modify them when displaying them in the program ;)
