uptill 6 divx on a Dvd
SkyNET
Post by SkyNET »
Hence at least 6 700mbyte divx can be put on 1 DVD5 disc;
I've tried to create a "dvd-cover"-template that can show all 6 movies with a picture & data.
Problems:
* the 2nd column is the front cover of the DVD-box; I haven't figured out yet how to get the "master data" align/sort from 2nd column to the front
* When you have 2cd divx of one movie (or more); I add "empty" movie titles which will move the titles to the "front" of the box.
* In order to get the "titles" on the side of the box; there are some "bulk" at the sides... You can just remove them when using the scissors on your A4 paper to get it to the correct dvd-box size
http://users.pandora.be/skynet/6filmdvd.frf
begin 0666 6filmdvd.frf
M%P`````3`$-A;F]N($U0-S,P(%!R:6YT97(`_P`!``":"P``-`@``$@`````
M````2````%H````!_____P(````V`````@`+`$UA<W1E<D1A=&$Q```````K
M````*`0``,\````T``4``0```````````/___Q\`````!@!;3F]N95T`````
M````__\```4`365M;S@`(`$``'````#<````*@````,````!````````````
M____'RP"```````!``@`6T%C=&]R<UT`````__\%`$%R:6%L``H`````````
M```````````"``````#___\````````%`$UE;6\S`#@````L````R`$``,X`
M```#``\``0```````````/___Q\L`@```````0````````#__P4`07)I86P`
M"@````````````````````(``````/___P`````!``@`4&EC='5R93$`1@``
M`#$```"4````PP````<````!````````````____'RP"```````!``D`6U!I
M8W1U<F5=`````/__`*8!``````4`365M;S0`WP```)@````>`0``60````,`
M```!````````````____'RP"```````!``T`6T1E<V-R:7!T:6]N70`!`!$`
M6U1R86YS;&%T9614:71L95T`__\/`%1I;65S($YE=R!2;VUA;@`(````````
M`````````````@``````____``````0`!0!,:6YE,0"@````Q```````````
M`````0`$``(```````````#___\?+`(``````````````/__!``%`$QI;F4T
M`-@```#T```````````````!``0``@```````````/___Q\L`@``````````
M````__\$``4`3&EN938`</[__^#^__^U`0````````$`"``!````````````
M____'RP"``````````````#__P``!0!-96UO,@#@````+@```!X!```.````
M`0````$```````````#W\<@`+`(```````$`+@!;665A<ET@(%M,96YG=&A=
M(&UI;BX@(%M#871E9V]R>5T@("A;0V]U;G1R>5TI``$`$0!;5')A;G-L871E
M9%1I=&QE70#__P4`07)I86P`!P````````````````````(``````/___P``
M``````4`365M;S$`X````#\````:`0``&0````$`#P`!````````````____
M'RP"```````!``\`6T]R:6=I;F%L5&ET;&5=`````/__!0!!<FEA;``*````
M`@``````"@```````@``````____``````0`!0!,:6YE.``,`@``^```````
M`````````0`$``(```````````#___\?+`(``````````````/__```%`$UE
M;6\U`.````!<````3````!(````#`````0```````````/___Q\L`@``````
M`0`,`%)E9VES<V5U<B`Z(`````#__P4`07)I86P`"@````(`````````````
M``(``````/___P````````4`365M;S8`,`$``%P```#,````$@````L````!
M````````````____'RP"```````!``H`6T1I<F5C=&]R70````#__P4`07)I
M86P`"@````````````````````(``````/___P````````4`365M;S<`X```
M`'`````\````$@````,````!````````````____'RP"```````!``H`06-T
M975R<R`Z(`````#__P4`07)I86P`"@````(```````````````(``````/__
M_P````````4`365M;SD`#`(``"P````4````T`````,`#P`!````````````
M____'RP"```````!`!@`6T]R:6=I;F%L5&ET;&5=("A;665A<ETI`````/__
M!0!!<FEA;``*````````````!@```P```@``````____````````!@!-96UO
M,3``(````"P````4````S@````,`#P`!````````````____'RP"```````!
M`!@`6T]R:6=I;F%L5&ET;&5=("A;665A<ETI`````/__!0!!<FEA;``*````
M````````!@```P```@``````____`````/X`````'P`,`$UO=FEE($9I96QD
M<PT'`"!.=6UB97(-"P`@365D:6%,86)E;`T*`"!-961I851Y<&4-!P`@4V]U
M<F-E#0D`($)O<G)O=V5R#0<`(%)A=&EN9PT%`"!$871E#0X`($]R:6=I;F%L
M5&ET;&4-$``@5')A;G-L871E9%1I=&QE#0D`($1I<F5C=&]R#0D`(%!R;V1U
M8V5R#0@`($-O=6YT<GD-"0`@0V%T96=O<GD-!0`@665A<@T'`"!,96YG=&@-
M!P`@06-T;W)S#00`(%523`T,`"!$97-C<FEP=&EO;@T)`"!#;VUM96YT<PT,
M`"!6:61E;T9O<FUA=`T-`"!6:61E;T)I=')A=&4-#``@075D:6]&;W)M870-
M#0`@075D:6]":71R871E#0H`($9R86UE<F%T90T*`"!,86YG=6%G97,-"@`@
M4W5B=&ET;&5S#0L`(%)E<V]L=71I;VX-!0`@4VEZ90T&`"!$:7-K<PT(`"!0
':6-T=7)E`&5S
[/url]
airmuze
How can i create a template with 3 films per page?
Post by airmuze »
Hi, I tried to create my personal template, using as model the List 1, but when i opened the report to print it, i only saw one film per page, not 3 as i wanted. How can i do? Because List 1 have 3 films per page, i only modified/added some variables to put them in spanish, my language, and y couldn´t see the 3 films again.
Can anybody help me?!?!
this program is amazing and i want to make lists of my films to give to my friends.
Other question is if with this soft i´ll we able to export to word, excel, power, etc. to lend to my friends
i´m wainting for this very much, but first i need to create a good report.
Thanks!!!!
Greetings from Argentina.
Be sure that the area of "master data" block does not cover the whole page, since it is the part that is repeated for each movie.
