i'ld like to find (part 3)...
ABNormal
Post by ABNormal »
a more flexible toolbar, where i can move icons (i'ld like to have add new data, import from file, import with script one after the other, and Find icon only later...)
so is it possible to add "move up/down buttons" into customize toolbar menu?
Thx a lot Antoine
ABN
I did not allow that because it was not easy to do and to store/load these settings. There are so few people that use toolbar customization that I prefer to wait for a ready-to-use solution made for Toolbar2000/TBX (what I use for the toolbars).
ABNormal
Post by ABNormal »
btw really thx a lot
ABN
