keeps asking for cd/dvd
nsh2005
Post by nsh2005 »
How come it keeps asking for a cd or dvd to be in the drive? It keeps asking when i start up or change the prefs.
It's pretty annoying..
Probably because it remembered that you have read info from a file that was on the CD.
I should try to correct that, but since it does not happen on my PC it is not easy.
While the program is closed, open moviecatalog.xml / prefs.xml (depending of your AMC version) and search for the letter of your CD (e.g. "d:\") then delete this value.
