Problem with IMDB script Large Pic
The Big Eye
Post by The Big Eye »
when i use the imdb script and i select the amazon large pic option, it gets it rarely (out of 99 movies 8 times) but when i use the amazon script directly, it does get the large pic. Can this be solved easily? or could i be doing some thing wrong?
When I ask the Amazon page using the URL given by IMDB, AMC usually receive a page with no picture, I do not know why. I haven't find out why AMC does not get the same page as the web browsers.
The Big Eye
but it worked better in the previous version of AMC
ps, great program though ;)
Well, it was not because of previous AMC versions but previous Amazon/IMDB versions :p It is not my fault if they change things on their site :D
