[DE] Beschreibung autom. einfügen
ich nutze nun die neueste (3.4.3) Version dieses genialen Programms.
Habe nun aber Probleme damit, die Beschreibungen und Bilder mit Hilfe der Scripts autom. einzufügen.
Was muss ich tun? :cry:
Und am Rande:
Schade das es hier keine "deutsche" Ecke gibt, denn mein engish is to bad for all understand and writing ...
c/u,
gueat
Re: [DE] Beschreibung autom. einfügen
Guest wrote:Hi,
ich nutze nun die neueste (3.5) Version dieses genialen Programms.
Und am Rande:
c/u,
gueat
Sorry I only understand English & French...
Hi antp,
excuse my english is verry bad ...
Im wrote:
im used the newest version from Ant movie catalog (3.5). Its verry, verry good !
But i have problems with the autom. Text and Picture download from scripts. I need only german informations from Movies and pictures, not english, and from all scripts they i foudet i havent all information, but not text and pictures.
What i must doing, for i can insert the text and pic ?
And behind this posting:
i missed a german corner, then my english its to bad for all understand and writig ...
c/u,
guest
There are maybe scripts for version 3.4.3 that import all in German, but you'll have to wait a little if you want some for version 3.5. Somebody will have to convert the scripts (all will be converted for the final 3.5 version).
PS: when I'll have some time, I'll switch to a different forum that will allow sub-categories. If I find somebody that can check all German threads like I do for English and French threads, then I could make a German subcategory dedicated to topics in this language ;)
@antp:
Thanks. I will wait for new scripts ..
c/u
guest
Hallo Guest,
bei mir klappt das Importieren von deutschen Beschreibungen ohne Probleme.
Ich verwende das Script 'OFDb (DE)' und habe auch schon (fast) alle Filme in der deutschen Datenbank gefunden. Suche unter 'Skripte'...
danke für den Tip !!!
Er funktioniert, mit Text und Bild. Einwandfrei !
Danke nochmals,
guest
