Sorting on YEAR
joly
Sorting on YEAR
Post by joly »
1. it only sorts from old to new, but you are aware of that.
But i have a problem with some movies, and changing the year by hand doesnt solve the problem.
eg.
20000 Leagues Under the Sea
The Guns of Navarone
The Good, The Bad & the Ugly
No matter what i try, i cant get them in the correct year.
On another note, is it possible to minimize all the years in one go, now i have to close them one by one.
Sorry, what's the problem exactly with the years? I do not understand what you mean :D Is it a problem for importing data from IMDB?
For the items in grouping mode, there is an option to select if you want to see them expanded or collapsed by default. And the shortcuts [Ctrl] [+] and [Ctrl] [-] allow to do that too.
joly
Post by joly »
The problem is when i add these movies, and use F6 -> imdb script,, and when i sort them afterwards on YEAR, these movies are put under <others>
Yet the year is filled in, and changing them doesnt help.
That's because in version 3.5 there is an option (enabled by default) in the Preferences windows to put together the values that are alone in their group.
I think that I should not enable this by default since you're not the first to ask a question about this "other" group :D
joly
Post by joly »
/me feels ashamed that he overlooked that setting Image
