Character Roles by Actors
Goobermaster
Post by Goobermaster »
I like to use the IMDb script to fill in my movie information and after downloading the latest script, notice that the actor field no longer contains the [(as Character So and So)] for each actor anymore. I like this useful tidbit and hope it may be re-added back into the script.
Sure appreciate all the hard work that goes into this, I use it to catalog my nearly 500 DVD's and automatically generate sql that my nukie site can read. :)
Thanks -
Goobermaster
As written in different places (the topics containing the script, the news, etc.) you can edit the script to change its options :p
Click "Editor" and follow comments
Goobermaster
Thanks antp - I didn't bother to look at that. I'll give it a go.
barfly
Post by barfly »
A minimal bug:
The "view page" button for the imdb script (maybe also for the other scripts) doesn't work.
Should work with the version included in AMC, but I probably forgot to update the version in /temp/scripts folder of my server, since I corrected this bug recently. I'll re-upload it now.
