IMDB broken again?
Andy-Hammer
IMDB broken again?
Post by Andy-Hammer »
Hello.
Yesterday I used IMDB and everything was OK. But right now script doesn't grabbed for information at all! Please, help!
THX.
Were you using the script that comes with the program or the new one available at viewtopic.php?t=1735 ?
For me this new one seems to still work.
Andy-Hammer
I was using IMDB (large pic). And this is renew script. I did it 3 weeks ago. And till today script was working fine!
Andy-Hammer
I checked IMDB. It's working, BUT.........without pictures. and when I opening actors window i saw just actors without cast. For example: was Arnold Schwarzenegger (as Conan) and now Arnold Schwarzenegger
Did you modify the options in the new script ? (clic Editor, then scroll down to "GetOption" function)
I have the same problem....IMDB script worked perfectly (the new one) but today it only gets "http://imdb.com/title/tt
<html" in the URL field and nothing more.
For what movie ?
For me the script available at the URL posted above still works...
I've tried the script you mentioned and it works. ?!?! But trust me, I had the new imdb script because it worked yesterday and the day before and so on....
Weird....anyway, thank you very much.
Actually there were two scripts :
- the one included in official AMC 3.4.3 version
- the one available on the other topic, from the link posted above.
This second one is a conversion of the AMC 3.5 script that I rewrote from scratch.
Both were working yesterday.
I guess that IMDB changes something yesterday that makes the first one not work anymore, but since the second one was differently written, it still works (it's maybe only luck :D)
JoeLansing
IMDB script change...
Post by JoeLansing »
I had the same problem. The above script fixed it. All is better now. Go support Ant via paypal!!!!!...:) Heck, Micro$oft won't support you like this. And I've got the feeling AntP isn't Bill Gates yet...:P - Joe
Andy-Hammer wrote:I checked IMDB. It's working, BUT.........without pictures. and when I opening actors window i saw just actors without cast. For example: was Arnold Schwarzenegger (as Conan) and now Arnold Schwarzenegger
i had this problem that actors window just show actors without cast too
no problem now :hihi:
i didn't exactly look at the new script which have an option to modify
'ActorsLayout': Result := 4;
thanks
