Sized picture in HTML-Export
de-37091
Post by de-37091 »
my pictures in the movie Catalog are 1600x1000 pixel.
The html-export need a function to resize this picture to a specify size e.g. 400x250 with keept the ratio.
Thanx
PS: moviecatalog is very nice tool
Currently you have to use an external program to make this resize on the exported images.
I plan to add resizing options in the future, but I cannot say when.
For me this works fine to keep the picture at normal (Large) size.
<img src="$$ITEM_PICTUREFILENAME" width="150" height="225" ></td>
Sure but this does not make the pictures smaller. When the pictures are very larges it is quite annoying if you want to put them on a site.
you need GD for this work
GD2+ PHP
DE-37091
Re: Sized picture in HTML-Export
Post by DE-37091 »
I've found it in the option dialog. :-\
Thanx
