Is there a way to make the scripts a bit more automated? :)
SuperflyTNT
Post by SuperflyTNT »
When I go to run the scripts I have found that the first thing i see is a prompt to hit "ok" if the correct title is in the box. Why? I have just grabbed this very nice looking Ant Movie Catalog, and I have imported my huge 1300+ movie database from Excel, which i had been using. I went to start to run a script to grab info from imdb, but then i had prompts for every little thing.
Is there a way that some of the prompting in the scripts can be automated out. Like for instance the description, can we set the script to just pick the longest one, or the top one or something. And I would see the toughest problems being with finding the correct movie, but most of the time it should be the most popular one with the title. Or is there a way that the script could do all the movies that it finds only one movie with that title and skip all the ones that need a prompt to go further, and come back to those movies all at once, so a person wouldn't have to sit there and micrmanage the script the whole time?
just some thoughts... ;) thanks everyone for these wonderful scriptZ ;)
Twink
Post by Twink »
if you run scripts from in the tools menu you can select multiple movies. I think it asks you less crap then
It is not too difficult to modify the script for that. I should do that, if I've few time, but if somebody else wants to do it, he can :)
phaelox
Post by phaelox »
I'm working on something, will post results soon ;)
SuperflyTNT
you guyz kick ass! ;) Thanks guyz, it iZ much appreciateD! ;) (to phae, SUz in the hizzow *L*)
watchout
Post by watchout »
hehehe LOL.. indeed Superfly.. :hihi:
phaelox
Post by phaelox »
Lol Supe :hihi:
Well, here's my stuff...
Batch-importing Features:
  • No more prompts (except when original title is empty)
  • When a search for a movie title leads to only one result on IMDb, IMDb will redirect you to that movie. The script would then assume the "http://us.imdb.com/Tsearch?title=Movie+Title" link as movie URL. This script will grab the real URL, no matter what. (IMHO, this should be in the regular IMDb script as well)
  • Choose whether to import a large picture, small picture or no picture by setting a simple True or False in the script Editor.
  • Choose whether to import any of the fields via the same way.
  • Choose to import the longest available description or the shortest
  • Import Translated Title (but only when it's actually a foreign movie, not regular alternate titles)
  • Choose to import Translated Title, but to not overwrite the Original Title you had filled in.
Bugs:
  • Probably, but none yet detected ;) (haven't had much time yet, to do extensive testing)
Note: Be sure to take a look at (and perhaps modify) the constants at the beginning of the script, as they control what gets imported and what does not.
IMDB (US) automated batch importing.ifs:
// SCRIPTING
// IMDB (US) automated batch importing (use Editor to change options)
// Note(!): This script will take first found Movie title, which in some cases
// will mean it will take the wrong movie title. However, this script will
// save you a ton of time when importing info for a large list. Just correct
// the falsely imported infos manually later. Be sure to make a backup of your
// list beforehand.
 *  Movie importation script for:                   *
 *      IMDB (US), http://us.imdb.com               *
 *  (c) 2002 Antoine Potten    antoine@buypin.com   *
 *  Improvements made by Danny Falkov               *
 *  Improvements made by Kai Blankenhorn            *
 *  Batch-import improvements made by YH            *
 *  For use with Ant Movie Catalog 3.3.0            *
 *  www.ant.be.tf/moviecatalog ··· www.buypin.com   *
program IMDb;
  // Set the following constants to True to import field, or False to skip field
  ImportURL = True;
  ImportOriginalTitle = True;
    ImportTranslatedTitle = True;
      LeaveOriginalTitle = True; // True will get Translated Title, yet Original Title field will remain same
  ImportYear = True;
  ImportRating = True;
  ImportPicture = True;
    ImportLargePicture = False; // If set to False small pic will be imported
  ImportDirector = True;
  ImportActors = True;
  ImportCountry = True;
  ImportCategory = True;
  ImportDescription = True;
    UseLongestDescription = False; // If set to False shortest description available will be imported
  ImportComments = True;
  ImportLength = True;
  ImportLanguage = True;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  TitleFound: Boolean;
  MovieURL: String;
  if pos('<TITLE>IMDb', Page.Text) = 0 then
    if ImportURL then
    AnalyzeMoviePage(Page)
    TitleFound := False;
    LineNr := 0;
    LineNr := FindLine('<H2><A NAME="top">Most popular searches</A></H2>', Page, LineNr);
    if LineNr > -1 then
      MovieURL := AddMoviesTitles(Page, LineNr);
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="mov">Movies</A></H2>', Page, LineNr);
    if (LineNr > -1) And Not (TitleFound) then
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="tvm">TV-Movies</A></H2>', Page, LineNr);
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="tvs">TV series</A></H2>', Page, LineNr);
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="vid">Made for video</A></H2>', Page, LineNr);
      TitleFound := True;
    if TitleFound then
      AnalyzePage(MovieURL);
  Line, Value, Value2, FullValue, OldOriginalTitle: string;
  LineNr, Desc, i: Integer;
  BeginPos, EndPos: Integer;
  Descriptions, OldTitleParts: TStringList;
  // Original Title & Year
  if (ImportOriginalTitle) or (ImportYear) then
    if LineNr > -1 then
      BeginPos := pos('<title>', Line);
      if BeginPos > 0 then
        BeginPos := BeginPos + 7;
      EndPos := pos('(', Line);
      if EndPos = 0 then
        EndPos := Length(Line);
      HTMLDecode(Value);
      if ImportOriginalTitle then
        OldOriginalTitle := GetField(fieldOriginalTitle);
      if (ImportTranslatedTitle) and Not (LeaveOriginalTitle) then
        EndPos := pos(')', Line);
        if ImportYear then
          SetField(fieldYear, Value);
  // Translated Title
  if ImportTranslatedTitle then
    OldTitleParts := TStringList.Create;
    // Tokenize OldOriginalTitle while removing certain chars/common words ("the", "of")
    Value := AnsiUpperCase(OldOriginalTitle);
    Value := StringReplace(StringReplace(Value, ',', ' '), ':', ' ');
    Value := StringReplace(StringReplace(Value, '(', ' '), ')', ' ');
    Value := StringReplace(StringReplace(Value, 'OF', ' '), 'THE', ' ');
    until Pos('  ', Value) = 0;
    Value := StringReplace(Trim(Value), ' ', ',');
    // Value now contains the original title (comma-separated) that was filled in before running the script
    Value2 := '';
    for i := 1 to Length(Value) do
      if Pos(',', Copy(Value, i, 1)) = 0 then
        Value2 := Value2 + Copy(Value, i, 1);
      if (Pos(',', Copy(Value, i, 1)) = 1) or (i = Length(Value)) then
        OldTitleParts.Add(Value2); // put each comma-separated value from Value into a separate string in TitleParts
        Value2 := '';
    for i := 0 to OldTitleParts.Count - 1 do
    // Begin comparing title parts (from the title originally filled in by moviedb owner) with
    // the 'true' Original Title (extracted from IMDb) to see if it's a foreign title and needs a Translated Title
      if Pos(OldTitleParts.GetString(i), AnsiUpperCase(GetField(fieldOriginalTitle))) <= 0 then
      begin // no match, must be a foreign title
        LineNr := FindLine('Also Known As', Page, 0);
        if LineNr > -1 then
          if Pos('Also Known As', Line) > 0 then
            BeginPos := Pos('Also Known As', Line) + 26;
            Value := Copy(Line, BeginPos, Length(Line) - BeginPos - 4);
            Value := StringReplace(Value, '<br>', '/ ');
    OldTitleParts.Free;
  // Rating
  if ImportRating then
    if LineNr > -1 then
      if Pos('awaiting', Line) > 0 then
        SetField(fieldRating, Value);
  // Direct Link (FIX: when IMDb finds only one entry for the movie title, the script assumes the search URL as Movie URL)
  // Before Fix: http://us.imdb.com/Tsearch?title=Final Fantasy%3A+The+Spirits+Within
  // After  Fix: http://us.imdb.com/Title?0173840
  if ImportURL then
    if Pos('Tsearch', GetField(fieldURL)) > 0 then
      if LineNr > -1 then
        if Pos('/Ratings?', Line) > 0 then
          BeginPos := pos('/Ratings?', Line) + 9;
          Value := 'http://us.imdb.com/Title?' + Copy(Line, BeginPos, 7);
          SetField(fieldURL, Value);
  // Picture
  if ImportPicture then
    LineNr := FindLine('<img alt="cover" align="left" src="http://posters.imdb.com/', Page, 0);
    if LineNr < 0 then
    if LineNr > -1 then
      BeginPos := pos('src="', Line) + 4;
      Delete(Line, 1, BeginPos);
      EndPos := pos('"', Line);
      if ImportLargePicture then
        Value := StringReplace(Value, 'MZZZZZZZ', 'LZZZZZZZ');
      GetPicture(Value, False); // False = do not store picture externally ; store it in the catalog file
  // Director
  if ImportDirector then
    if LineNr > -1 then
      FullValue := '';
        EndPos := pos('</a>', Line);
          if FullValue <> '' then
        Delete(Line, 1, EndPos);
      until Pos('</a>', Line) = 0;
      HTMLDecode(FullValue);
  // Actors
  if ImportActors then
    LineNr := FindLine('Cast overview', Page, 0);
    if LineNr = -1 then
      LineNr := FindLine('cast overview', Page, 0);
    if LineNr = -1 then
      LineNr := FindLine('Complete credited cast', Page, 0);
    if LineNr > -1 then
      FullValue := '';
        BeginPos := Pos('<td valign="top">', Line);
          if EndPos = 0 then
            EndPos := Pos('</td>', Line);
            BeginPos := pos('.... </td><td valign="top">', Line);
              EndPos := pos('</td></tr>', Line);
              BeginPos := BeginPos + 27;
              if Value2 <> '' then
                Value := Value + ' (as ' + Value2 + ')';
          Line := '';
      until Line = '';
  // Country
  if ImportCountry then
    LineNr := FindLine('Country:', Page, 0);
    if LineNr > -1 then
      HTMLDecode(Value);
  // Category
  if ImportCategory then
    LineNr := FindLine('Genre:', Page, 0);
    if LineNr > -1 then
      HTMLDecode(Value);
  // Description
  if ImportDescription then
    Descriptions := TStringList.Create;
    LineNr := FindLine('Plot Summary:', Page, 0);
    if LineNr < 1 then
      LineNr := FindLine('Plot Outline:', Page, 0);
    if LineNr > -1 then
      BeginPos := pos('</b>', Line) + 5;
      EndPos := pos('<a href', Line);
      if EndPos < 1 then
      EndPos := pos('<a href="/Plot?', Line);
      if EndPos < 1 then
        EndPos := pos('<br><br>', Line);
      if EndPos < 1 then
      HTMLDecode(Value);
      Descriptions.Add(Value);
      BeginPos := pos('/Plot?', Line);
      EndPos := pos('">(more)', Line);
      Desc := 0;
      if (BeginPos <> 0) and (EndPos <> 0) then
        GetDescriptions(Value, Descriptions);
        For i := 0 to Descriptions.Count - 1 do
          if UseLongestDescription then
            if Length(Descriptions.GetString(i)) > Length(Descriptions.GetString(Desc)) then
              Desc := i
            if Length(Descriptions.GetString(i)) < Length(Descriptions.GetString(Desc)) then
              Desc := i;
      Value := '';
      SetField(fieldDescription, Descriptions.GetString(Desc));
    Descriptions.Free;
  // Comments
  if ImportComments then
    LineNr := FindLine('<b>Summary:</b>', Page, 0);
    if LineNr > -1 then
      Value := '';
        LineNr := LineNr + 1;
        EndPos := Pos('</blockquote>', Line);
        if EndPos = 0 then
          EndPos := EndPos - 2;
        Value := Value + Copy(Line, 1, EndPos) + ' ';
      until Pos('</blockquote>', Line) > 0;
      HTMLDecode(Value);
      Value := StringReplace(Value, #13#10+' ', #13#10);
  // Length
  if ImportLength then
    LineNr := FindLine('Runtime:', Page, 0);
    if LineNr > -1 then
      EndPos := pos(' min', Line);
      if EndPos = 0 then
        EndPos := pos('  /', Line);
      if EndPos = 0 then
      if Pos(':', Line) < EndPos then
        BeginPos := Pos(':', Line) + 1
        BeginPos := 1;
      SetField(fieldLength, Value);
  // Language
  if ImportLanguage then
    LineNr := FindLine('Language:', Page, 0);
    if LineNr > -1 then
      if EndPos = 0 then
  DisplayResults;
procedure GetDescriptions(Address: string; var Descriptions: TStringlist);
  Line, Value: string;
  Page.Text := GetPage('http://us.imdb.com' + Address);
  LineNr := FindLine('<P CLASS="plotpar">', Page, 0);
  while LineNr > -1 do
    Value := '';
        BeginPos := BeginPos + 10
        BeginPos := 1;
      EndPos := pos('</P>', Line);
      if EndPos < 1 then
        EndPos := Length(Line) + 1;
      if Value <> '' then
        Value := Value + ' ';
    until (pos('</P>', Line) > 0) or (LineNr = Page.Count);
    LineNr := FindLine('<P CLASS="plotpar">', Page, LineNr);
function AddMoviesTitles(Page: TStringList; var LineNr: Integer): String;
  StartPos: Integer;
    StartPos := pos('="', Line);
    if StartPos > 0 then
      Startpos := Startpos + 2;
      MovieAddress := copy(Line, StartPos, pos('">', Line) - StartPos);
      MovieTitle := copy(Line, StartPos, pos('</A>', Line) - StartPos);
      HTMLDecode(Movietitle);
      if Length(Result) <= 0 then
        Result := 'http://us.imdb.com' + MovieAddress;
  until pos('</OL>', Line) > 0;
  if CheckVersion(3,2,1) then
    if MovieName <> '' then
//      AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName)+'&restrict=Movies+only');
      AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName));
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.2.1)');
phaelox
Post by phaelox »
The Translated Title import is prolly not done the neatest way possible, but what the hell, it's scripting for a scripting component anyway and it does work (for me anyway *L*).. Hope it works for you guys.
Thanks for your script, I will probably put it with the other scripts ;)
phaelox wrote: [*]When a search for a movie title leads to only one result on IMDb, IMDb will redirect you to that movie. The script would then assume the "http://us.imdb.com/Tsearch?title=Movie+Title" link as movie URL. This script will grab the real URL, no matter what. (IMHO, this should be in the regular IMDb script as well)
Sure, I will add that :)
Just a remark : you kept "// GETINFO SCRIPTING" at the top of the file, you should only keep "// SCRIPTING" since this script is not made for the classic information importation (where you can import for only one movie)
phaelox
Post by phaelox »
Ah, right you are. (Hadn't really looked into that yet.)
Edited it out of my post above. ;)
phaelox
Post by phaelox »
Another thing.
The way I scripted it, when it needs a translated title (w/ foreign movies), it takes all the translated/alternate titles in one string, separated by a forward slash. Personally I like it that way, but if preferred I could further split it up and take only the "English title" alternate Title or if not there, the "(UK)" title or if also not there, the first alternate title.
Example bit from IMDb movie page for the movie "Gwan geun shut daam":
<b class="ch">Also Known As</a>:</b><br>And Now You're Dead (1998) (UK) <br>Enter the Eagles (1998) (Hong Kong: English title) <br>
I'll probably enhance this later.
phaelox
SuperflyTNT
i'm running it right now! ;) been ten minutes of running and no prompts yet *L* ;)
oop, thereZ one..."IMDB service temporarily unavailable" then i clicked ok and it went back to what it was doing ;) Guess thatz a good sign ;)
Thanks man, this looks to be just what i needed!!! ;) I'll test it out and try a few different constants or whateverZ ;) Muchos graciaZ ;)
The only LIL BITTY THing I can see so far that seems like it would be easy enough to fix is all the popupZ saying something bout an IMDB error (connection refuses, connection reset, gracefully disconnected, service temporarily unavailable). If there is a way to automate the script to hit "ok" or enter on these prompts then it would be perfect ;) otherwise you still have to kinda oversee the whole thing, because one of these usually pops up on average every 5-10 minutes ;)
Thanks again, this script is still running strong and its been over an hour *L* (lot of movies to grab shit for) but it seems to be running very fast ;)
All finished! ;) and it worked Great! only found a few movies with wrong info in 'em and I don't care *L* this script rocks for mass importation!!!!! ;)
oh, but by the way, It didn't import the ratingZ, but still, itZ almost perfect ;)
SuperflyTNT
hey wow, i fixed the Rating part of the script ;)
i just compared it to another script where the rating worked and cut and pasted the right shit, and after a few tries i got it to work ;)
and thanks to your very intuitive addition of True/False on/off switches, I'm gonna go ahead and run your mass script to only import Rating ;)
this would kinda be useful anyways to update your ratings every few months ;) so hereZ Your script with all falses except for ratings, and the modified rating part ;)
EDIT *L* I just tried running this and it gives me a Script error every few movies "IMDB position at 7575 out of range" *L* so well, ok i guess i did it "almost" right *L* well anywayzz this might help ya so i'll post it, but it doesn't completely work... *L*
OK, I checked some more, and this only seems to be giving that error on movies with "awaiting 5 votes" under user rating. like:
http://amazon.imdb.com/Title?0189066
so it must need a line like:
"Line := Page.GetString(LineNr + 4);
if Pos('awaiting', Line) > 0 then"
like Phaelox had, but then when you add that it will no longer grab the rating at all. So the values must be off on that line, but i have no idea what most of it means *L* so I just figured this might help pinpoint the problem to make it easier to fix *L*
THANKS again ;)
welp, hereZ the one that works at getting ratings only, mass import for all, except it gives that error when it comes to a movie without a user rating ;)
// SCRIPTING
// list beforehand.
*  Batch-import improvements made by Youri Heijnen *
program IMDb;
  ImportURL = False;
  ImportOriginalTitle = False;
    ImportTranslatedTitle = False;
      LeaveOriginalTitle = False; // True will get Translated Title, yet Original Title field will remain same
  ImportYear = False;
  ImportPicture = False;
  ImportDirector = False;
  ImportActors = False;
  ImportCountry = False;
  ImportCategory = False;
  ImportDescription = False;
  ImportComments = False;
  ImportLength = False;
  ImportLanguage = False;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  MovieURL: String;
    if ImportURL then
    LineNr := 0;
    if LineNr > -1 then
      TitleFound := True;
      TitleFound := True;
      TitleFound := True;
      TitleFound := True;
      TitleFound := True;
    if TitleFound then
    if LineNr > -1 then
      if EndPos = 0 then
      HTMLDecode(Value);
        if ImportYear then
  // Translated Title
    Value2 := '';
        Value2 := '';
        if LineNr > -1 then
    OldTitleParts.Free;
  // Rating
    if LineNr > -1 then
  if ImportURL then
      if LineNr > -1 then
  // Picture
    if LineNr < 0 then
    if LineNr > -1 then
  // Director
    if LineNr > -1 then
      FullValue := '';
  // Actors
    if LineNr = -1 then
    if LineNr = -1 then
    if LineNr > -1 then
      FullValue := '';
          if EndPos = 0 then
          Line := '';
      until Line = '';
  // Country
    if LineNr > -1 then
      HTMLDecode(Value);
  // Category
    if LineNr > -1 then
      HTMLDecode(Value);
  // Description
    if LineNr < 1 then
    if LineNr > -1 then
      if EndPos < 1 then
      if EndPos < 1 then
      if EndPos < 1 then
      HTMLDecode(Value);
      Desc := 0;
              Desc := i
              Desc := i;
      Value := '';
    Descriptions.Free;
  // Comments
    if LineNr > -1 then
      Value := '';
        if EndPos = 0 then
      HTMLDecode(Value);
  // Length
    if LineNr > -1 then
      if EndPos = 0 then
      if EndPos = 0 then
        BeginPos := 1;
  // Language
    if LineNr > -1 then
      if EndPos = 0 then
  DisplayResults;
    Value := '';
        BeginPos := 1;
      if EndPos < 1 then
      if Value <> '' then
  StartPos: Integer;
SuperflyTNT wrote: so it must need a line like:
Actually this line is there to avoid the error when it is awaiting 5 ratings, but I made a small mistake : you have to replace the ">" by a "="
I never get errors while connecting to IMDB. If you get so many it is either that you have a poor connection, or that you make too many request to their server, and that's not a so good idea since they may notify it and block your IP or block Ant Movie Catalog (that for the moment uses its own agent identifier)
phaelox
Post by phaelox »
Hehehe, nice to hear it worked so good for ya ('cept for the ratings). And like antp says, IMDb connection errors... whew.. you must be hammering the server with your 1300+ movies :lol: ;)
antp, it can't be a poor connection, he's got 1300+ movies in his list. A list like that you don't get on a poor connection. :P I think his connection is so fast, that he can make a *lot* of requests in a *very* short period of time. But if ppl are going to use batch import for large lists, perhaps better to remove the agent identifier then or at least include an option to not use it (like most ripping progs do)?
Btw, I actually knew of that rating fix, read about it on this forum somewhere, but forgot to include it :P
Bugfixes:
  • Rating import fixed
// SCRIPTING
// list beforehand.
program IMDb;
  ImportURL = True;
  ImportYear = True;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  MovieURL: String;
    if ImportURL then
    LineNr := 0;
    if LineNr > -1 then
      TitleFound := True;
      TitleFound := True;
      TitleFound := True;
      TitleFound := True;
      TitleFound := True;
    if TitleFound then
    if LineNr > -1 then
      if EndPos = 0 then
      HTMLDecode(Value);
        if ImportYear then
  // Translated Title
    Value2 := '';
        Value2 := '';
        if LineNr > -1 then
    OldTitleParts.Free;
  // Rating
    if LineNr > -1 then
      if Pos('awaiting', Line) = 0 then
  if ImportURL then
      if LineNr > -1 then
  // Picture
    if LineNr < 0 then
    if LineNr > -1 then
  // Director
    if LineNr > -1 then
      FullValue := '';
  // Actors
    if LineNr = -1 then
    if LineNr = -1 then
    if LineNr > -1 then
      FullValue := '';
          if EndPos = 0 then
          Line := '';
      until Line = '';
  // Country
    if LineNr > -1 then
      HTMLDecode(Value);
  // Category
    if LineNr > -1 then
      HTMLDecode(Value);
  // Description
    if LineNr < 1 then
    if LineNr > -1 then
      if EndPos < 1 then
      if EndPos < 1 then
      if EndPos < 1 then
      HTMLDecode(Value);
      Desc := 0;
              Desc := i
              Desc := i;
      Value := '';
    Descriptions.Free;
  // Comments
    if LineNr > -1 then
      Value := '';
        if EndPos = 0 then
      HTMLDecode(Value);
  // Length
    if LineNr > -1 then
      if EndPos = 0 then
      if EndPos = 0 then
        BeginPos := 1;
  // Language
    if LineNr > -1 then
      if EndPos = 0 then
  DisplayResults;
    Value := '';
        BeginPos := 1;
      if EndPos < 1 then
      if Value <> '' then
  StartPos: Integer;
I think that what I should make is a pause of 1 or 2 seconds before connecting the server.
Or maybe put it in the script : see if Sleep(1000); is accepted (pause of 1000 milliseconds)
SuperflyTNT
yeah the pause idea sounds like a winner ;) It definately semeed like a hammering problem.
how do ya put the sleep 1000 in the script? (this is the first time i have ever dealt with scripts for the most part) *L* ;)
Thanks guyz for your help, this catalog is really becoming one hell of a handy tool! ;)
before each "GetPage" line, add a line with :
Sleep(1000);
If it does not work or causes an error, I'll have to add that into the program itself.
phaelox
Unknown identifier
Post by phaelox »
Sleep is not a supported procedure apparently. Sounds like a plan to add it though. The way it is now, the programs pops up a msgbox when it can't connect, but how about not popping up a msgbox when a page can't be loaded and a retry to get that page (maybe max. 2 or 3 tries and then pop up a showmessage if still no go)? (only on scripting, not on getinfo)
phaelox
