If you put 6 divx into a Dvd-r....
ABNormal
Post by ABNormal »
use this template:
select from 1 to 6 titles, and here it is what happens:
Encoded by Decode/Encode DLL for Unlicensed Application: contact sales@funduc.com
Content-Description: "Unlicensed Application: contact sales@funduc.com"
Content-Type: application\octet-stream; name="6 DivX in 1 DVDr.frf"
Content-Transfer-Encoding: UUENCODED
Content-Disposition: attachment; filename="6 DivX in 1 DVDr.frf"
begin 644 6 DivX in 1 DVDr.frf
M%P`````7`$504T].(%-T>6QU<R!#-C0@4V5R:65S`/\``0```@@``!0%``"7
M`````````)``````````````__\#``````````(`"P!-87-T97)$871A,0``
M````$````-X"``#<````,``%``$```````````#___\?``````8`6TYO;F5=
M`````````/__```%`$UE;6\R`)@````0````D````-X````#``\``0``````
M`````/___Q\L`@``````````````__\%`$%R:6%L``H`````````````````
M```"``````#___\``````0`(`%!I8W1U<F4R`)@````L````D````,(````'
M`````0```````````/___Q\L`@```````0`)`%M0:6-T=7)E70````#__P`^
M`0``!``%`$QI;F4Q```````````````````````!``0``@```````````/__
M_Q\L`@``````````````__\$``4`3&EN934`7`(``)@!``````````````$`
M!``"````````````____'RP"``````````````#__P0`!0!,:6YE-@!<`@``
M?`$``````````````0`$``(```````````#___\?+`(``````````````/__
M!``%`$QI;F4W`%P"``"P```````````````!``0``@```````````/___Q\L
M`@``````````````__\```4`365M;S$`F````!````"0````&@````,````!
M````````````____'RP"```````!`!$`6U1R86YS;&%T9614:71L95T`````
M__\+`%=O;&8G<R!"86YE``L`````````_P`"```````"``````#___\`````
M_@`````?``P`36]V:64@1FEE;&1S#0<`($YU;6)E<@T+`"!-961I84QA8F5L
M#0H`($UE9&EA5'EP90T'`"!3;W5R8V4-"0`@0F]R<F]W97(-!P`@4F%T:6YG
M#04`($1A=&4-#@`@3W)I9VEN86Q4:71L90T0`"!4<F%N<VQA=&5D5&ET;&4-
M"0`@1&ER96-T;W(-"0`@4')O9'5C97(-"``@0V]U;G1R>0T)`"!#871E9V]R
M>0T%`"!996%R#0<`($QE;F=T:`T'`"!!8W1O<G,-!``@55),#0P`($1E<V-R
M:7!T:6]N#0D`($-O;6UE;G1S#0P`(%9I9&5O1F]R;6%T#0T`(%9I9&5O0FET
M<F%T90T,`"!!=61I;T9O<FUA=`T-`"!!=61I;T)I=')A=&4-"@`@1G)A;65R
M871E#0H`($QA;F=U86=E<PT*`"!3=6)T:71L97,-"P`@4F5S;VQU=&EO;@T%
;`"!3:7IE#08`($1I<VMS#0@`(%!I8W1U<F4`
--=======Next-Part-23642332=========--
SkyNet
"up till 6" movies on a <dvd cover>
Post by SkyNet »
I've created a template but i'm not 100% satisfied with the result
http://users.pandora.be/skynet/6filmdvd.frf
I'm trying to create a dvd cover for a dvd box;
containing uptill 6 movies (divx) with a picture, short desc and if possible adding the title on the "gap" between the 2 columns I created.
Somehow this doesn't seem feasable; sometimes a "title" doesn't get printed or the 6 movies (2x 3) don't get aligned very good.
Anyone knows how to fix this?
Perhaps something with these "grids"?
