Saving together with picture
coki
Post by coki »
Is there any way I can save catalog in other directory together with all pictures. In my case I have 600 movies and all of them have pictures and everything is in one directory. I want to save Catalog in other directory together with pictures
i want to do that becouse i want to install 3.5 version and want to do a backup and becouse i have a lot of pictueres that are not linked with catalog and they are just a garbage
Currently the pictures are not copied/moved when you do a Save As.
You can convert your catalog to .amc format if you use .xml, then use the "Image import" tool at ftp://ftp2.antp.be/antp/software/amcimgimport2.zip to store the pictures inside the catalog. Then save this catalog again as .xml somewhere else to re-export the pictures.
Thank you :grinking:
