I like this program very much and I cant wait the day of realese AntMovieCatalog 3.5. When it will be finally realesed ? Becouse I really really hate the beta versions ?
And I have one more question will the program include possibility to update alredy entered movies just by using URL of movie (becouse there are a lot of people like me that are not good in scripting )
Thank you for making such a great program like this, you are really a king I hope that this tradition will continue for a long time
I do not know when it will be done.
I have to fix few small things, update both english and french help file, update the other translations and wait reply from translators, convert remaining old scripts to the new format.
About updating movies using the URL, it depends of the scripts, not the program itself. The way it is designed I can't easily force the script to use a URL rather than do a search.
