[UPD EN] All Movie Guide 1.1
Enjoy it.
 - - - - - -  updated - - - - - - -
:D
Authors=Hubert Kosior, KaraGarga, Chetan Rao, Donna Huffman, R_V, Fulvio53s03
Title=All Movie Guide
Description=All Movie Guide detailed info import with picture
Site=https://www.allmovie.com
Language=EN
Version=1.1 / Marzo 2021
Requires=3.5.0
Comments=a bug corrected by Antoine Potten|completely rewritten again for the AllRovi site by Chetan Rao.|Reworked March 2009 for changes to AllMovieGuide by Donna Huffman|Rewritten for Allmovie.com by R_V (V 0.7.0 <-> 0.7.2 Feb 2014)|Updated by Fulvio53s03 on 27 feb 2021
RequiresMovies=1
CategoryOptions=3|3|1=Only import first category|2=Import all categories and divide by "/"|3=Import all categories and divide by ","
ProducerOptions=0|0|0=Import Production Companies into Producer Field|1=Import Releaser Company into Producer Field
SynopsisOptions=1|1|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Synopsis
ReviewOptions=2|2|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Review
AwardsOptions=2|2|1=Import into Description Field|2=Import into Comments Field|0=DO NOT import Awards List
CastOptions=3|3|1=Import Cast divided by ";"|2=Import Cast as a list (AMG Default)|3=Import Cast as a list (like IMDB)|4=Import Cast as a list within paranthesis|5=Import Cast within paranthesis
FieldforCredits=2|2|0=DO NOT import Production Credits|1=Import Production Credits into Description Field|2=Import Production Credits into Comments Field
CreditsOptions=2|2|1=Import Credits as a list (like AMG)|2=Import Credits as a list (like IMDB)|3=Import Credits as a list (within paranthesis)
CharacteristicsOptions=1|1|0=DO NOT import Characteristics|1=Import into Description Field
Picture=1|1|1=Big|2=Small
MaxResults=5000|5000|100=Maximum search results returned|200=|5000=|8000=
BatchMode=0|0|0=Normal working mode|1=Batch mode: if the URL field is filled, it imports from that page instead of asking for a title
[Parameters]
program AllMovie;
  StringUtils1;
  crlf = #13#10;                        // carriage return/line feed
  tab  = #9;
  PageURL: string;
  PageReview, initchar, endchar: string;
  UpdateFile: TStringList;
// simple string procedures
  while Pos(Old, S) > 0 do
  Result := S;
function RemoveWhiteSpace(S : string) : string;
    Result := StringReplaceAll(S, tab, '');
    Result := StringReplaceAll(Result, crlf, '');
    Result := Trim(Result);
function GetStringFromList(Content, Delimiter: string): string;
  Data : string;
    while(true) do
      Data := TextBetween(Content, '">', '</a>');
      if (Length(Data) = 0) then
        break;
      HTMLRemoveTags(Data);
      Data := RemoveWhiteSpace(Data);
      Result := Result + Data + Delimiter + ' ';
      Content := TextAfter(Content, '</a>');
    // remove trailing delimiter
    if (Copy(Result, Length(Result), 1) = Delimiter) then
      Result := Copy(Result, 0, Length(Result) - 1);
function GetStringFromTable(Content, Delimiter, ColDelim : string): string; // for actors
  Data, cast_role   : string;
  ColLen : Integer;
  ColLen   := Length(ColDelim);
  Result   := '';
  Content := TextBetween(Content, '<div class="cast_container">', '<span>Jump to: ') + '<div class="cast_container">';
  //Content := TextAfter(Content, '<div class="cast_container">');
  while(true) do
    Data := TextBetween(Content, '<div class="cast_name artist-name">', '<div class="cast_container">');
    // make a unique delimiter between character and name
    cast_role := Fulltrim(TextBetween(Data, '<div class="cast_role">', '</div>')); // if there is no cast_role next go line 80
    Data := StringReplaceAll(Data, '<div class="cast_role">', ColDelim);
    HTMLDecode(Data);
      break;
    // make sure we don't start with the ColDelim
    if (Copy(Data, 0, ColLen) = ColDelim) then
      Data := Copy(Data, ColLen + 1, Length(Data));
    // make sure we don't end with the ColDelim
    if (Copy(Data, Length(Data) - ColLen + 1, ColLen) = ColDelim) then
      Data := Copy(Data, 1, Length(Data) - ColLen);
    if cast_role <> '' then // if there is no cast_role necessary for actors format options
    Result  := Result + Data + '## ';
function GetStringFromTable2(Content, Delimiter, ColDelim : string): string; // for crew
  Data   : string;
  ColLen : Integer;
  Result   := '';
  Content := TextBetween(Content, '<div class="crew_container">', '<span>Jump to: ') + '<div class="crew_container">';
  //Content := TextAfter(Content, '<div class="crew_container">');
  while(true) do
    Data := TextBetween(Content, '<div class="crew_name artist-name">', '<div class="crew_container">');
    Data := StringReplaceAll(Data, '<div class="crew_role">', ColDelim);
    HTMLDecode(Data);
      break;
    Result  := Result + Data + Delimiter;
function GetStringFromAwardsTable(Content, Delimiter, ColDelim : string): string;
  Data       : string;
  RowData    : string;
  ColLen     : Integer;
  AwardTitle : string;
  AwardType  : string;
  AwardRecps : string;
  AwardYear  : string;
  Presenter  : string;
  Result   := '';
  while(true) do
    Data      := TextBetween(Content, '<h3 class="award">', '</table>');
    Presenter := FullTrim( TextBetween(Content, '<h3 class="award">', '</h3>') );
    HTMLDecode(Data);
      break;
    RowData := Data;
    RowData := TextAfter(Rowdata, '<tbody>');
    while(true) do
      Data := TextBetween(RowData, '<tr>', '</tr>');
        break;
      Data := StringReplace(Data, '<td class="award-type"', '<td class="award-type"><td class="award-type"');
      Data := StringReplace(Data, '<td class="award-title"', '<td class="award-title"><td class="award-title"');
      Data := StringReplace(Data, '<td class="award-year"', '<td class="award-year"><td class="award-year"');
      AwardType  := TextBetween(Data, '<td class="award-type">', '</td>');
      AwardTitle := TextBetween(Data, '<td class="award-title">', '</td>');
      AwardRecps := TextBetween(Data, '<div class="recipients">', '</div>');
      AwardYear  := TextBetween(Data, '<td class="award-year">', '</td>');
      HTMLRemoveTags(AwardType);
      HTMLRemoveTags(AwardTitle);
      HTMLRemoveTags(AwardRecps);
      HTMLRemoveTags(AwardYear);
      AwardType := FullTrim(AwardType);
      AwardTitle := FullTrim(AwardTitle);
      AwardRecps := FullTrim(AwardRecps);
      AwardYear := FullTrim(AwardYear);
      if (Length(AwardType) > 0) then
        AwardType := ' (' + AwardType + ')';
      Data       := AwardTitle + AwardType + ColDelim + AwardRecps + ColDelim + AwardYear + ColDelim + Presenter;
      Result     := Result + Trim(Data) + Delimiter;
      RowData    := TextAfter(RowData, '</tr>');
    Content := TextAfter(Content, '</table>');
function StrOccurs(Text, SearchText: string) : integer;
   loc, len : integer;
  StrOccurs := 0;
  len       := length(SearchText);
  loc       := 1;
    loc := Pos(SearchText, Text);
    if loc > 0 then
      StrOccurs := StrOccurs + 1;
      loc  := loc + len;
      Text := Copy(Text, loc, Length(Text) - loc);
  until(loc <= 0);
// Loads and analyses search results page
procedure AnalyzeSearchResults(MovieTitle: string);
  NumResults, MaxResults, Code : Integer;
  Address, MovieResults : string;
  MaxResults := GetOption('MaxResults');
  Page.Text := GetPage('https://www.allmovie.com/search/movies/' + MovieTitle);
  NumResults := 0;
  if Pos('search results for ', Page.Text) > 0 then
    MovieResults := TextBetween(Page.Text, '<li class="filter-movies active">', '</li>');
    MovieResults := StringReplace(MovieResults, ',', '');
    MovieResults := StringReplace(MovieResults, '+', '');
    NumResults := StrToInt(TextBetween(MovieResults, '(', ')'), Code);
    if Code > 0 then
      NumResults := 0;
    if (NumResults > 0) and (NumResults <= MaxResults) then
      PickTreeAdd(IntToStr(NumResults) + ' results found for "' + MovieName + '"', '');
      AddMoviesTitles(MovieTitle);
        AnalyzePage(Address);
  if (NumResults > MaxResults) then
    ShowMessage('Sorry, there are too many possible matches, please adjust your search and retry.')
  if NumResults = 0 then
    ShowMessage('Sorry, no movies found.');
  // cleanup
// Loads and analyses a movie page
  if CanSetField(fieldURL) then SetField(FieldURL, Address);
  AnalyzeMoviePage(Address, Page);
// Extracts movie details from page
procedure AnalyzeMoviePage(Address: String; MoviePage: TStringList);
  Page: string;
  Value, Value2, Temp, Writer, Composer: string;
  Content: string;
  Delimiter : string;
  Dummy: string;
  SubPage: TStringList;
  Rating : real;
  Page    := MoviePage.Text;
  SubPage := TStringList.Create;
  // Original title
//2021-02-28    Value := TextBetween(Page, '<h2 class="movie-title" itemprop="name">', '<');
    Value := TextBetween(Page, '<h2 class="movie-title">', '<') + '</h2>';             //2021-02-28
    Value := UTF8Decode(Value);
    HTMLRemoveTags(Value);
//2021-0-28    HTMLDecode(Value);
    Value := FullTrim(Value);
  Content := Page;
  // Year
    Value := TextBetween(Page, '<span class="release-year">(', ')');
    SetField(fieldYear, Value);
  // Length
    Value := TextBetween(Page, 'Run Time - <span>', ' min');
    SetField(fieldLength, Value);
  // Country
    Value := TextBetween(Page, 'Countries - <span>', '</span>');
  // AKA -> translated title
    Value := TextBetween(Page, '<h4>Alternate Title</h4>', '</span>');
  // Rating
//    Value := TextBetween(page, 'itemprop="ratingValue">', '</div>');
//    Value := TextBetween(page, '"aggregateRating": {', '}');
//    Value := TextBetween(Value, '"ratingValue": "', '"');
    initchar := '<div class="allmovie-rating';
    endchar  := '</div>';
    Value := initchar + TextBetween(page, '<div class="allmovie-rating', '</div>') + endchar;
    Rating := StrToFloat(Value);
    SetField(fieldRating, FloatToStr(Rating));
  // Certification
  if CheckVersion(4,2,0) = True then
    Value := TextBetween(Content, 'MPAA Rating - <span>', '</span>');
    Value := AnsiUpperCase(Value);
    Value := StringReplace(Value, 'PG13', 'PG-13');
    Value := StringReplace(Value, 'NC17', 'NC-17');
    SetField(fieldCertification, Value);
  // Director
    Value := TextBetween(Content, 'Directed by ', '</span>');
    Value := GetStringFromList(Value, ',');
  // Genre -> category
    Value := TextBetween(Content, 'Genres - ', '</span');
    if GetOption('CategoryOptions') = 1 then
      Value := TextBetween(Value, '">', '</a>');
      if GetOption('CategoryOptions') = 2 then
        Delimiter := '/';
      if GetOption('CategoryOptions') = 3 then
        Delimiter := ',';
      Dummy := GetStringFromList(Value, Delimiter);
      // sub-genres
      Value := TextBetween(Content, 'Sub-Genres - ', '</span>');
      Value := GetStringFromList(Value, Delimiter);
      if Length(Value) > 0 then
        Value := Dummy + Delimiter + ' ' + Value
        Value := Dummy;
  // Producing company  -> producer
    Value := '';
    if GetOption('ProducerOptions') = 0 then
      Value := TextBetween(Page, '<h4>Produced by</h4>', '</div>');
    if GetOption('ProducerOptions') = 1 then
      Value := TextBetween(Page, '<h4>Released By</h4>', '</div>');
  // Image
  if CanSetPicture then
    Value := TextBetween(Page, ' <div class="poster">', '</div>');
    Value := TextBetween(Value, '<img src="', '"');
    Value := StringReplace(Value, '?partner=allrovi.com', '');
    Value := StringReplace(Value, 'https', 'http');
    if GetOption('Picture') = 1 then
    Delete(Value, Pos('_derived', Value), (Pos('_m0/', Value))-(Pos('_derived', Value))+4);
    // don't bother getting the default "no-image"
    if ( (Length(Value) > 0) and (Pos('no-image', Value) = 0) ) then GetPicture(Value);
// Plot synopsis
  if CanSetField(fieldComments) or CanSetField(fieldDescription) then
    // store the author of the synopsis
    Dummy := TextBetween(Page, '<h4 class="review-author headline">', '</h4>');
    HTMLRemoveTags(Dummy);                  //autore della Synopsi
    Dummy := fullTrim(Dummy) + CRLF + CRLF;                  //autore della Synopsi
    Dummy := RemoveSpaces(Dummy, True);
    Dummy := stringReplace(Dummy, 'Synopsis by ', '');
//************************ fine  vecchie istruzioni *****************************
    Value := TextBetween(Page, '<section class="review read-more synopsis">', '</section>');
    value := TextBetween(value, '<div class="text">', '</div>');            //2021-02-27
    value := StringReplace(value, '</p> <p>', ('</p> <p>' + CRLF));         //2021-02-28 stacca paragrafi
    value := StringReplace(value, './n', ('.' + CRLF));         //2021-02-28 stacca paragrafi
    Value := 'AMG SYNOPSIS: ' + fulltrim(Value) + ' -- ' + fulltrim(Dummy);
    if GetOption('SynopsisOptions') = 1 then
    if GetOption('SynopsisOptions') = 2 then
  // Characteristics
  if (CanSetField(fieldComments)) and (GetOption('CharacteristicsOptions') > 0) then
  Value := TextBetween(Page, '<h3>Characteristics</h3>', '</section>');
  Value := StringReplace(Value, '</h4>', ' : </h4>');
  Value := StringReplace(Value, '</4>', ' : </h4>'); // because sometimes the html code is broken on AMG site
  Value := StringReplace(Value, '<h4>', '<h4>##');
  HTMLRemovetags(Value);
  HTMLDecode(Value);
  Value := RemoveSpaces(Value, True);
  Value := StringReplace(Value, '##', crlf);
  SetField(fieldDescription, GetField(fieldDescription) + CRLF + CRLF + 'CHARACTERISTICS:' + Value + crlf + crlf);
  // Review -> description
  if (CanSetField(fieldComments) or CanSetField(fieldDescription))
  and (GetOption('ReviewOptions') > 0) and (Pos('<li class="tab review">', Page) > 0) then
    // get the page
    SubPage.Text := GetPage(Address + '/review');
    PageReview := Subpage.Text;
    // store the author of the review
    initchar := '<section class="review">';
    endchar  := '</section>';
    Dummy := initchar + TextBetween(PageReview, initchar, endchar) + endchar;
    Content := textbetween(Dummy, '</h4>', endchar) + endchar;
    initchar := '<span>';
    endchar  := '</span>';
    Dummy := initchar + TextBetween(Dummy, initchar, endchar) + endchar;
    HTMLRemoveTags(Dummy);                                                   //autore della Review
    // get the review
    initchar := '<p>';
    Content := initchar + TextBetween(Content, initchar, endchar);
    Content := RemoveSpaces(Content, True);
    Content := StringReplace(Content, '</p> <p>', ('</p> <p>' + CRLF));
    HTMLRemoveTags(Content);
    HTMLDecode(Content);
    Value := UTF8Decode(Content);
    if (Length(Value) > 0) then
      Value := Fulltrim(Value) + ' -- ' + Dummy + CRLF + CRLF;
    if GetOption('ReviewOptions') = 1 then
	  //if (GetOption('SynopsisOptions')= 1) or (GetOption('AwardsOptions')= 1) or (GetOption('FieldforCredits')= 1) then
	    Value := 'AMG REVIEW: ' + Value;
    if GetOption('ReviewOptions') = 2 then
	  //if (GetOption('SynopsisOptions')= 2) or (GetOption('AwardsOptions')= 2) or (GetOption('FieldforCredits')= 2) then
  // Awards -> description
  if (CanSetField(fieldComments) or CanSetField(fieldDescription)) and (GetOption('AwardsOptions') > 0) and (Pos('<li class="tab awards">', Page) > 0) then
    // get the page
    SubPage.Text := GetPage(Address + '/awards');
    // get the awards panel content -- this yields the awards
    Content := TextAfter(SubPage.Text, '<div class="awards-box">');
    Value := GetStringFromAwardsTable(Content, '~~ ', '||');
    Value := StringReplace(Value, '~~ ', #13#10);
    Value := StringReplace(Value, '||', ' - ');
      if GetOption('AwardsOptions') = 1 then
        SetField(fieldDescription, GetField(fieldDescription) + 'AWARDS:' +#13#10 + Value + #13#10);
      if GetOption('AwardsOptions') = 2 then
        SetField(fieldComments, GetField(fieldComments) + 'AWARDS:' + #13#10 + Value + #13#10);
  // Cast -> actors
  if CanSetField(fieldActors) or CanSetField(fieldComments) or CanSetField(fieldDescription) or (CheckVersion(4,2,0) and (CanSetField(fieldWriter) or CanSetField(fieldComposer))) then
    // get the page
    SubPage.Text := GetPage(Address + '/cast-crew');
    // get the center panel content -- this yields the Cast table
    Content := TextBetween(SubPage.Text, '<h2>Cast</h2>', '<h2>Crew</h2>');
    Value := GetStringFromTable(Content, '~~ ', '||');
      // remove double spaces if only actor name given
      while Pos('  ', Value) > 0 do
        Delete(Value, Pos('  ', Value), 2);
      if GetOption('CastOptions') = 1 then
        Value := StringReplaceAll(Value, '~~ ', ';');
        Value := StringReplace(Value, '## ', ';');
        Value := StringReplaceAll(Value, '||', '-');
        SetField(fieldActors, Value);
      if GetOption('CastOptions') = 2 then
        Value := StringReplace(Value, '## ', #13#10);
        if (Copy(Value, Length(Value) - 1, 2) = #13#10) then
          Value := Copy(Value, 0, Length(Value) - 2);
      if GetOption('CastOptions') = 3 then
        Value := StringReplace(Value, '||', ' ... ');
      if GetOption('CastOptions') = 4 then
        Value := StringReplace(Value, '~~ ', ')'+#13#10);
        Value := StringReplace(Value, '||', ' (');
      if GetOption('CastOptions') = 5 then
        Value := StringReplace(Value, '~~ ', '), ');
        Value := StringReplace(Value, '## ', ', ');
        if (Copy(Value, Length(Value) - 1, 2) = ', ') then
    // ProductionCredits -> Comments/Description
    Content := TextBetween(SubPage.Text, '<h2>Crew</h2>', '</section>');
    // transform the weirdly formatted list into a pseudo table so we can
    // reuse existing
    Value := GetStringFromTable2(Content, '~~ ', '||');
      // remove double spaces if only name given
      // begin get composer and writer
        Value2 := '%Name : '+Value;
        Value2 := StringReplace(Value2, '~~ ', ']#'+#13#10+'%Name : ');
        Value2 := deleteEnd(Value2, '%Name : ');
        Value2 := StringReplace(Value2, '||', ' [');
        if (Copy(Value2, Length(Value2) - 1, 2) = #13#10) then
        Value2 := Copy(Value2, 0, Length(Value2) - 2);
        // start loop
        While Pos('#', Value2) > 0 do
          Temp := TextBetween(Value2, '%', '#');
          if Pos('Composer', Temp) > 0 then
          Composer := Composer+TextBetween(Temp, 'Name : ', ' [')+', ';
          if (Pos('Screenwriter', Temp) > 0) OR (Pos('Screen Story', Temp) > 0) then
          Writer := Writer+TextBetween(Temp, 'Name : ', ' [')+', ';
          Delete(Value2,1,Pos('#',Value2));
        // end loop
        Composer := deleteEnd(Composer, ', ');
        SetField(fieldComposer,Composer);
        Writer := deleteEnd(Writer, ', ');
        SetField(fieldWriter,Writer);
      // end get composer and writer
      if GetOption('CreditsOptions') = 1 then
      if GetOption('CreditsOptions') = 2 then
      if GetOption('CreditsOptions') = 3 then
      if GetOption('FieldforCredits') = 1 then
        SetField(fieldDescription, GetField(fieldDescription) + 'PRODUCTION CREDITS:' + #13#10 + Value + crlf + crlf);
      if GetOption('FieldforCredits') = 2 then
        SetField(fieldComments, GetField(fieldComments) + 'PRODUCTION CREDITS:' + #13#10 + Value + crlf + crlf);
  SubPage.Free;
  // remove trailing newline from description or comments
  Value := GetField(fieldDescription);
  While Copy(Value, Length(Value) - 1, 2) = #13#10 do
  Value := GetField(fieldComments);
// Adds movie titles from search results to tree
procedure AddMoviesTitles(Title : string{; NumResults: Integer});
  PageText : string;
  SearchAddress : string;
  MovieTitle, MovieAddress, MovieYear, MovieDirector, Temp: string;
  SearchAddress := 'https://www.allmovie.com/search/movies/' + Title;
  Page.Text := GetPage(SearchAddress);
  PageText := Page.Text;
  Delete(PageText, 1, Pos('<ul class="search-results">', PageText)-1);
  // Every movie entry begins with string "<tr>"
  while Pos('<li class="movie">', PageText) > 0 do
    Temp := TextBetween(PageText, '<li class="movie">', '</li>');
    MovieAddress := 'https://www.allmovie.com/movie' + TextBetween(Temp, '<a href="https://www.allmovie.com/movie', '"');
    MovieTitle := UTF8Decode(TextBetween(Temp, MovieAddress+'">', '</a>'));
    MovieYear := TextBetween(Temp, MovieTitle+'</a>', '</div>');
    MovieYear := FullTrim(MovieYear);
    MovieDirector := UTF8Decode(TextBetween(Temp, 'Directed by: ', '</div>'));
    HTMLRemoveTags(MovieDirector);
    MovieDirector := FullTrim(MovieDirector);
    If MovieDirector <> '' then
    MovieDirector := ' by ' + MovieDirector;
    MovieTitle := MovieTitle + ' ' + MovieYear + MovieDirector;
    // add movie to list
    // remove the entry we just processed
    CutAfter(PageText, '</li>');
// Extracts single movie detail (like director, genre) from page
  Result := '';
    CutBefore(Page, StartTag);
    if Length(CutTag) > 0 then
      CutAfter(Page, CutTag);
    // remove html tags and decode html string
    HTMLRemoveTags(Result);
    HTMLDecode(Result);
    Result := RemoveWhiteSpace(Result);
//  ShowMessage('DEBUG: GetStringFromHTML - StartTag "'+StartTag+'", CutTag "'+CutTag+'", EndTag "'+EndTag+'", Result "'+Result+'" ___ '+Page);
// Delete substring of a string if end string
function deleteEnd(Value, EndValue : String) : String;
  if copy(Value,length(Value)-length(EndValue)+1,length(Value)) = EndValue then
        Value := copy(Value,1,length(Value)-length(EndValue));
  result := Value;
// Program
      if ShowWarning('Old version of file "Stringutils1.pas" detected: v'+IntToStr(StringUtils1_Version)+#13#10+'The script requires at least version 7.'+#13#10+'Download and install latest version now ?') = True then
          UpdateFile.Text := GetPage('http://update.antp.be/amc/scripts/StringUtils1.pas');
          UpdateFile.Free;
          ShowInformation('StringUtils1 has been updated. Please restart "All Movie Guide" script now. Thank you.');
          Exit;
          ShowInformation('You can download latest version of "StringUtils1.pas" using script [ UPDATE SCRIPTS ] or via http://update.antp.be/amc/scripts');
          Exit;
  // Check AMC version
  if CheckVersion(4,2,1) then
    MovieName := GetField(fieldUrl);
    if (GetOption('BatchMode') = 1) and (Pos('allmovie.com', MovieName) > 0) then
      if Pos('https', MovieName) > 0 then
      AnalyzePage(MovieName)
      AnalyzePage(StringReplace(MovieName, 'http', 'https'));
      if MovieName = '' then MovieName := GetField(fieldTranslatedTitle);
      if Input('All Movie Import', 'Enter title (only letters, digits and spaces) or URL:', MovieName) then
        if Pos('allmovie.com', MovieName) > 0 then
        AnalyzeSearchResults( StringReplace(URLEncode(MovieName), '%20', '+') );
  if ShowWarning('This script requires a newer version of Ant Movie Catalog'+#13#10+'at least the 4.2.1 BETA version available here : '+#13#10+'http://forum.antp.be/phpbb2/viewtopic.php?t=4844'+#13#10#13#10+'Click on ''Ok'' to launch directly the adress in your browser') = True then
  Launch('http://forum.antp.be/phpbb2/viewtopic.php?t=4844', '');
Lemaireus
Re: [UPD EN] All Movie Guide 1.1
Post by Lemaireus »
Fulvio, the only bit in which I got lucky was in finding help in you. The rest of my luck draws purely from the hours you have devoted to setting this script right. Thank you.
The script is now perfect in every regard, with only one formatting issue that remains to be cleaned up. It does not pick up the line space that separates paragraphs.
This is how the review of "The Revenant" https://www.allmovie.com/movie/the-reve ... 171/review should look after the script has imported the text, with space after paragraphs:
But this is how it looks at the moment--I have marked the places which need an extra line's space for paragraph break with red diamond shapes (notice the one place in which a new paragraph begins in the same line, highlighted with a blue square):
The review on the All Movie Guide website, with correctly formatted paragraphs with space https://www.allmovie.com/movie/the-reve ... 171/review:
Dare I hope that it wouldn't be too difficult to clean up the formatting, for you, after all, have practically built the entire script all over again! Thank you so much, Fuvlio!
Lemaireus wrote: 2021-03-02 18:08:10 Thank you so much, Fulvio!
:innocent:
Lemaireus
Post by Lemaireus »
Lemaireus wrote: 2021-03-02 18:08:10 Dare I hope that it wouldn't be too difficult to clean up the formatting, for you, after all, have practically built the entire script all over again! Thank you so much, Fuvlio!
The complete line, Fulvio, quote the complete line. :hihi:
Thank you! :grinking:
Lemaireus
Post by Lemaireus »
Still looking for someone to clean up the script which is nearly perfect, except one bug: it doesn't pick up the formatting of the text from the review section of the All Movie Guide website.
Lemaireus wrote: 2021-03-02 18:08:10 The script is now perfect in every regard, with only one formatting issue that remains to be cleaned up. It does not pick up the line space that separates paragraphs.
Dare I hope that it wouldn't be too difficult to clean up the formatting . . .
