Minutes to hour convertion
binoyt
Post by binoyt »
It would be possible to calculate the durations in hour instead of the minutes? (e.g. 130 minutes > 2h10)
Calculate, yes, but do what with it then ?
Currently it is not possible to show it like that in the main window or use it in the export. It may be possible to use it in printed reports, since there is a script tool integrated in it.
binoyt
Post by binoyt »
Yes, I would like see it in on my export page.
What is this script ? (I use the template Twink based in xml and Javascript)
As I said it is not possible in export with the program itself.
It is probably possible with the templates that use PHP or XSL (if I remember well, some of Twink's templates use that) but I can't help you :/
The script tool that I mentionned is for printing, not exporting.
