I really like AMC, but as far as i know i have to first add a new movie before running a script to import data.
Is it possible to have a script automatically insert a new record in the database ?
Add Movie and Run Script
scorpion7552
Re: Add Movie and Run Script
In the Preferences you can enable the option to automatically open script window when adding a movie. With this option enabled, the "add movie" button will do what you wantFrenzy wrote:I really like AMC, but as far as i know i have to first add a new movie before running a script to import data.
Thanks, i will try thatantp wrote:In the Preferences you can enable the option to automatically open script window when adding a movie. With this option enabled, the "add movie" button will do what you wantFrenzy wrote:I really like AMC, but as far as i know i have to first add a new movie before running a script to import data.
